Just dropped in a 600hp"need prop" >
Old 05-11-2008 | 07:29 AM
Default Just dropped in a 600hp"need prop"
I have a 288 sunsation and this week I pulled the 496HO and dropped in a custom built 600hp+ 540 motor. I am thinking 28 or 30 4 blade anyone have any other suggestions?
Whassup is offline
Old 05-11-2008 | 09:51 AM
What prop and RPM's were you getting with the old set-up?
It will be easier to figure knowing how your hull performed with the original set-up.
Carder is offline
Old 05-11-2008 | 09:13 PM
I was running a 4 blade 24 pitch at 5000 with 425hp, 70 mph. I will be running will say 600hp @ 5400-5500
Whassup is offline
Old 05-11-2008 | 09:16 PM
ak
i just rerigged my 24ft baja with a 630hp 509ci,i too have a 24 pt bravo one prop that just spins and blows out if you get on it too much,i am waiting for a labbed 23 pt 3 blade and i am going to try a 29 pt 4 blade.
ak is offline
Old 05-12-2008 | 08:50 AM
UNSANE's Avatar
I would probably start with a 28 Bravo. Because of your new found power, your boat might list to port because of the torque. If that's the case, switch to a LH rotation.
UNSANE is offline
Old 05-12-2008 | 10:45 AM
if it lists to port, try putting a torque tab on the skeg....changing to LH may only change the direction of the list.......I would start with a 28p Bravo 1
thedonz is offline
Old 05-13-2008 | 06:15 PM
RJBBC's Avatar
Registered User
Congratulations on the new power. Who built your engine? What did you do with the take out? I am thinking of doing something similar with our boat. I am not sure if supercharging our 454MAG or upgrading to a NA 540 is the best route. I am confident 600HP is where our famiy truckster needs to be. A 28 B1 labbed is where I would start to pull 5500RPM in most weather conditions with that power and hull. However my opinion is novice at best.
RJBBC is offline
Old 05-13-2008 | 08:55 PM
you need 28 3 blade then check your rpm . 4 blade prop on baja no good lift the back of boat up then you chine walk
bajabob is offline
Old 05-13-2008 | 09:04 PM
socalstone's Avatar
28 B1 stock or 30 B1 labbed.
Mine is a 26 outlaw (5200lbs) with 600sci spins a 28 great right out of the box. Stock 30 B1 was a little too much. Labbed the 30 and it's working well.
socalstone is offline
Old 05-14-2008 | 02:44 AM
articfriends's Avatar
What rpm was your peak? Smitty
articfriends is offline
