Baja Wire Color Code >
Old 05-12-2008 | 12:02 AM
Nightlife1970's Avatar
Default Baja Wire Color Code
I bought some original Baja gauges. I am told that they are Teleflex gauges. These gauges have the connections in a plug, there are not seperate terminals on the gauges. I am trying to figure out the color codes on the wires.
I have figured out that the Black is ground, Blue is lights, and I belive that Purple is the ignition switch. Now what I don't know is what the Grey wire is on the Tach/Hour gauge. Also don't know what the Tan wire is on water temp gauge, what the light blue is on the oil pressure gauge, and the pink wire is on the fuel gauge.
Anyone have any Ideas?
Nightlife1970 is offline
Old 05-12-2008 | 08:33 AM
Dock Holiday's Avatar
Charter Member #34
Those wires are from your senders on the engines and the tank.
Dock Holiday is offline
Old 05-12-2008 | 11:52 PM
mroutlaw_'s Avatar
Dave, I'll call ya tomorrow. (5-13-08)
I'm puttin in my bezels. Maybe I can fill ya in on some of the wires from my gauges
mroutlaw_ is offline
Old 05-13-2008 | 08:35 AM
Wally's Avatar
Were doomed!
the gray wire is the actual tach signal coming from the coil....the other wires are coming from the sending units and would get hooked up to the terminal on the gauge labled "S" if it has one
-Wally
Wally is offline
Old 05-14-2008 | 11:44 AM
Your codes are correct and they do go on the "s" post. Also on mine the trim gage is brown with white stripe.
As I am redoing my gauges and have oh so much fun.
knockld is offline
Old 06-03-2008 | 10:34 PM
SSComp's Avatar
Already posted on another thread:
Blk -Grounds-General
Blk/Brn -Pump Grounds
Blk/Red -Voltmeter Grounds
Blk/Org -Isolated Accessory Grounds
Blk/Yel -ignition stop
Blk/Grn -Water Level Sender Ground
Blk/Blu -Lighting Grounds
Blk/Gry -Nav Light Grounds
Blk/Wht -Battery Parallel Solenoid
Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
Brn/Red -Pumps, Bilge or Sump
Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
Brn/Yel -Baitwell or Aerator
Brn/Grn -Fresh Water Pump/Water Maker
Brn/Blu -Head Pump
Brn/Vio -Washdown Pump
Brn/Wht -trim pos sender
Red - Battery Feeds Unprotected
Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
Pink -Fuel Sender
Org/Blk -Audio System Feed
Org/Brn -Electric Head-Sanitation System
Org/Red -Wiper Port
Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
Org/Yel -Diesel Pre-heat
Org/Grn -Wiper Stbd
Org/Blu -Communications Equipment
Org/Vio -Navigation Equipment
Org/Wht -Wiper Center
Yel/Blk -Choke - Neutral saftey trans mounted
Yel/Red -Start Solenoid(starting circut), Neutral Safety
Yel/Org -Powered Ventilation, Fans
Yellow -Bilge Blowers -(also alternator DC output)
Yel/Wht -Rudder Angle Sender
Grn/Red -Stop Solenoid/Kill Switch
Grn/Yel -AC Grounding
Green -Bonding
Grn/Wht -Engine Trim in and or tilt down
Grn/Org -Engine Independent Trim down
Blu/Blk -Cabin Lights
Blu/Brn -Oil Temp Send
Blu/Red -Cabin or Cockpit Lights Port
Blu/Org -Engine Independent Tilt Up
Blu/Yel -Lighting Circuits to Remote Send
Blu/Grn -Cabin or Cockpit Lights Stbd
Blu -Instrument & General Lighting
Blu/Vio -Courtesy, Boarding Lighting
Blu/Wht -Engine Trim Outand/or Tilt Up
Light Blue -Oil Pressure
Vio/Red -Eng. or Generator B+ from Breaker
Vio/Yel -I/O Trim Up (ballast bypass)
Vio/Grn -I/O Trim Down
Vio -12v Ignition-Generator or Engine
Vio/Wht -Trim "Trailer" switch
Gry/Blk -Mast Light
Gry/Red -Spotlight Remote
Gry/Org -Docking Lights
Gry/Grn -Strobe or Beacon
Gry/Blu -Spreader/Flood Lights
Gry/Vio -Windlass/Winch
Gray -Navigation (running) Lights, Tach. Send
Gry/Wht -Anchor Light
Wht/Brn -Temp. Alarm or Indicator
Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Org -Fire Alarm or Indicator
Wht/Yel -Air Flow Alarm or Indicator
Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Blu -Oil Press Alarm or Indicator
Wht/Vio -Voltage Alarm or Indicator
White -General Alarm Usage, Yamaha Kill Switch
Tan - Water Temp sender
Tan/Blu -Warning system sense wire (Audio warning)
Pink -Fuel sender
SSComp is offline
jmherbert
0
06-14-2007 05:18 PM
Jim Diesel
Detailing, Painting, & Fiberglass
3
10-06-2006 12:53 PM
rfweber
Baja
3
05-01-2004 08:25 AM
barron
2
01-25-2003 06:31 PM
Elite Marine
7
11-04-2002 08:46 AM
