Rub rail always coming loose!? >
Old 05-18-2008 | 09:56 PM
Default Rub rail always coming loose!?
My rub rail I'm tightening up two or three times a year. Used lock tight, didn't work. Put a little bigger stainless screws in it so it would be tighter still comes loose. Anyone else have this problem? What have you done?
nova26 is offline
Old 05-18-2008 | 09:57 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Can you gain acesss to the back side and thru bolt it?
US1 Fountain is offline
Old 05-18-2008 | 10:01 PM
I don't know, but I wil check it out. Thanks!
nova26 is offline
Old 05-19-2008 | 01:55 AM
By bigger screws, do you mean longer???
I suspect the threads are getting loose from the vibration and retightening. Pull the screws out and put a little 5200 on the threads and then screw them back in.
Griff is offline
Old 05-19-2008 | 09:04 AM
Never heard of 5200 where do you get it? I did put bigger screws in. Thanks Dan.
nova26 is offline
Old 05-19-2008 | 09:52 AM
It is made by 3M and any Marine store should have it
danh63 is offline
Old 05-19-2008 | 10:33 AM
Had similar problems in the past. Use larger and course thread screws, dip it in silicone caulk and that will stop the viboration, and getting them lose. If you can get some rubber/sst washers with the screws that will also help.
PARADOX is offline
Old 05-19-2008 | 10:39 AM
DORaymond's Avatar
I had the same problem with a Donzi Z25 that I had. The hull and the top deck were joined together using the same screws that held on the rub rail on. I guess the boat flexed enough during running that the screws constantly came loose. The 5200 might help, would be better to through bolt it where you can.
DORaymond is offline
Old 05-19-2008 | 11:55 AM
Like was said, 3M 5200. Its a high strength marine adhesive caulk. I've used it on some snap screws and they never came loose again. Any Marine store should have it.
Through bolting with some nyloc nuts would be great, but a LOT more work and I doubt you can get to the backs of all the screws.
Griff is offline
Old 05-19-2008 | 11:57 AM
jhiguy377's Avatar
thru-bolt and backing plate wherever possible- good luck-jeff
jhiguy377 is offline
