GM Power Steering Pump
Old 05-19-2008 | 11:37 AM
Default GM Power Steering Pump
Can you use the old GM Power Steering pump in place of the Mercs? Is there any difference other than price? This is on a boat with twin ram external assist.
Run_em_hard is offline
Old 05-19-2008 | 11:40 AM
I've been using one for about 5 years on a 575SCi
with WPM external steering.
It's not like electrical/fuel items where things like
flameproofing is an issue. I believe the only difference
between the auto parts store pump and the one
you get from Merc. is that Merc. paints it for
corrosion control.
Pesky Varmint
Pesky Varmint is offline
Old 05-19-2008 | 11:42 AM
29KILROY's Avatar
Yes you can.
29KILROY is offline
Old 05-19-2008 | 11:55 AM
Tibbstoy2's Avatar
I also use a GM pump (actually Summit automotive pump - same style) - the only thing I had to do is cut off the merc fitting from my hose and switch it to an automotive flare fitting.
I had this done in 10 minutes at my local automotive. The steering is perfectly smooth, no orifice changes necessary at the inlet - even with full hydraulic steering at an idle.
If memory serves, I think I saved $350 going the summit route.
Tibbstoy2 is offline
Old 05-19-2008 | 12:55 PM
Registered User
The automotive pump limits you to that reservoir size, unless you have an adapter cap, which I was never fond of. The automotive pumps also don't put out the same pressure. I'd talk to your steering manufacturer for suggestions.
The automotive pumps can be made to work but after it's all said & done, you might not be saving anything.
Chris Sunkin is offline
Old 05-22-2008 | 12:09 AM
KCHOTBOAT's Avatar
Charter Member #737
What I did it the past was buy a automotive pump and replace the reservoir with a merc reservoir from a bad merc pump. If you want a really good pump send your pump to Turnone he sets them up for all types of racing. He did the pump on my car.
KCHOTBOAT is offline
Old 05-27-2008 | 11:47 AM
blue thunder's Avatar
I would think you could buy the automotive pump and reuse the reservoir and pressure control spring, shims from the marine pump and end up with the merc rated output pressure. What do you think?
BT
blue thunder is offline
Old 05-27-2008 | 02:34 PM
Strip Poker 388's Avatar
Rob
The orfice jet I found was diff . On my 89 Scarab I got a pump for a 70 Chevelle and it was close I ended up reusing the old orfice and outer housing off the boat and the new guts.
Here is some om my 500efi pump
http://www.offshoreonly.com/forums/s...power+sterring
Strip Poker 388 is offline
jbrauer
04-23-2015 12:24 PM
Revd Up
5
07-01-2007 01:03 AM
Johno
4
06-30-2003 05:21 PM
fishead
1
06-18-2002 09:42 PM
