Are you legal??
Old 05-20-2008 | 12:41 PM
Default Are you legal??
These newly introduced performance mufflers, the XPM525 are now available. These new silencers address the J-2005 SAE test that is now the standard in many states including California. In a recent independent test, these silencers showed a 12.2-decibel noise reduction at idle speed when mounted on the Mercury 525 engine package. This brought the test boat down to 88db passing the stringent California noise ordinance enacted this year. When installed on a test boat equipped with the 496 engine package, the mufflers brought it down to 88db. The XPM525’s are constructed entirely from 316L stainless steel in order to provide the maximum corrosion resistance available in saltwater applications. These mufflers do not have any moving parts or packing to wear out. The significant sound reduction is accomplished with a 5-inch 2-phase expansion chamber in conjunction with a center sound wave baffle. The unique down-turned design helps to keep spray and carbon residue from accumulating on the boats transom. Heavy-duty external exhaust flappers are included to prevent any chance of water ingestion through the exhaust system. Installation is simple. The XPM525 muffler system is designed to clamp onto any 4” O.D. tailpipe or exhaust tip using an integral stainless band clamp and a 1/8” set screw for added security. The mufflers are 12-1/2” in overall length.The meticulous hand polished finish bring these mufflers to a show quality shine making them a beautiful addition to any boat while maintaining their necessary functionality. Sold in pairs. Give our sales staff a call today for yours! Starting at $469.99
Hardin Marine is offline
Old 05-20-2008 | 12:52 PM
Strip Poker 388's Avatar
Rob
do ya make these that bolt/clamp on the tail pipes?
Strip Poker 388 is offline
Old 05-20-2008 | 01:09 PM
We sure do SP388,
These are normally $489.99, let me know if you have any questions.
Old 05-20-2008 | 04:44 PM
Rob
Originally Posted by Hardin Marine
We sure do SP388,
I guess they have the same guts/effect?
Old 05-20-2008 | 07:20 PM
Yes you are exactly correct, one utilizes a clamp for attaching to a 4" exhaust tip and the other has a typical mounting flange welded on for a transom mounted install.
Here is a picture at the very end of the tip looking inside.
and here is a picture of the clamp on version installed on one of our displays.
Old 05-20-2008 | 07:25 PM
will it fit over a angle cut?
Westcoast is offline
Old 05-29-2008 | 03:58 PM
No they wont, they require a straight cut tip in order to have enough clamping surface.
Old 05-29-2008 | 03:59 PM
Most definitely, one features the clamp and the other features a ring to be mounted on the transom.
Old 05-29-2008 | 10:42 PM
30 outlaw 2005's Avatar
Is that cost for the pair or each?
30 outlaw 2005 is offline
Old 05-30-2008 | 07:51 AM
What is the horsepower/performance loss on the 525 Mercs?
RaggedEdge is offline
