what is a Supper Leggera 41'
Born from a World Championship race boat, the 41 Super Leggera has lines that are smooth and sleek. Outerlimits took the R&D they did in the last two years of racing at home and abroad, and created a boat that is a World Champion on any continent.
The new hull design not only results in superior speed and handling, but also increases comfort with a softer ride. The stand-up bolster configuration provides the comfort of the canopied race boat, yet with the pleasure of the open air and cockpit. The superior handling results from the finely tuned bottom, so while racers cut buoys on a dime, Poker Runners will arrive at card stops with ease. The cornering ability of this hull is absolutely amazing. The construction of this boat is typical of all Outerlimits boats with a carbon fiber deck paired with an epoxy, e-glass hull, all post-cured in a computerized oven.
Luxury does not take a back seat to full-throttle fun, with a full cabin featuring a stand-up head, shower, a full V-berth, two large mid cabin storage lockers, and all the accouterments of other Outerlimits models. Passengers can enjoy the exciting ride, all the comforts and an integrated swim platform. The cockpit sports a dash made of hand stitched leather and suede, a GPS chart plotter, side-by- side stand-up bolsters with drop down bottoms and a removable 3 rd front seat bolster.
Available with a wide range of power options, including the new silent underwater muffling system introduced by Mercruiser, the technical options are also numerous, enabling the owner to select from top-notch electronics, interiors, upholstery, paint and finishes. The Super Leggera is all a powerboater could want.
standard equipment & features
LOA 41' 6" , Beam 9' 2 " , Deadrise 24 degrees , Draft 36" , Hull Weight 9,000 lbs , Fuel Capacity 200 gallons , Engines Twin Mercury Racing 700 SCi with NXT drives (dry sump), Exhaust Mercury Racing X-haust Noise Reduction System*
(Stage 1)
(Stage 1)
