Ok to leave onboard charger plugged in for extended periods? >
Old 05-21-2008 | 10:28 AM
florida gator's Avatar
Default Ok to leave onboard charger plugged in for extended periods?
I plugged in my onboard charger yesterday before leaving town for several days and forgot to unplug prior to leaving. Is it ok to leave a charger hooked up or should I find someone to go by my house and unplug?
Answer should be good for me long term since I am often on the road for work and would like to know the batteries are charged when returning.
florida gator is offline
Old 05-21-2008 | 10:35 AM
BY U BOY's Avatar
You should be fine> thats what they are made for.
BY U BOY is offline
Old 05-21-2008 | 10:43 AM
Dock Holiday's Avatar
Charter Member #34
I leave mine on all winter.
Dock Holiday is offline
Old 05-21-2008 | 12:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Does yours drop down to the 'float/maintainer' cycle after reaching full charge?
US1 Fountain is offline
Old 05-21-2008 | 03:52 PM
Steve Zuckerman's Avatar
Hi Guys,
I run one too. They are great. It also comes in handy dockside when 110V is available, allowing me to run lights/fans/stereo/DVD/etc without having to worry with shore power wiring.
The only thing to be wary of is a voltage spike from lightning.
I have seen it burn out an onboard charging system. I can't remember if it fried anything else (on a friend's boat).
I think it would help the other systems (ECU/ignition/stereo/etc) to make sure the battery switch is off to isolate them from a voltage spike (the hot side, anyway) coming through the charger and batteries.
Steve
Steve Zuckerman is offline
Old 05-22-2008 | 10:00 AM
depends on whether it will shut down when batts fully charged and float...some just keep charging and boil the batts to death
ezstriper is offline
Old 05-22-2008 | 11:32 AM
I'm not sure what kind it is. I have really only used it for short periods just prior to going out. I guess I will see Monday. Thanks for the input.
Old 05-22-2008 | 11:39 AM
Velocity Vector's Avatar
Crazy Energy
If your boat looks like a melted ice cream cone when you get back you left it on to long.
Velocity Vector is offline
Old 05-22-2008 | 12:36 PM
I follow these recommendations (see page 2). They are not a fan of trickle chargers...
http://www.eastpenn-deka.com/assets/base/0273.pdf
4mulafastech is offline
Old 05-22-2008 | 01:14 PM
offthefront's Avatar
A trickle charger is exactly as named and always provides a small amount of current to maintain voltage levels ....the new smart chargers are susposed to be able to monitor voltage and not overcharge ....not sure how well they work ....but I do know that since I added an onboard charger all my battery problems ended .....m
offthefront is offline
