TRS drive oil fill?
Old 05-21-2008 | 11:07 AM
Default TRS drive oil fill?
Ok how do you fill htese things? I have a drain which I would fill my bravo thru but there is no top screw to check level? The dipstick inside the Transom is just a resivor to keep the drive full I think.
GoFastSonic is offline
Old 05-21-2008 | 11:13 AM
jeff32's Avatar
you got it. inside transom!
jeff32 is offline
Old 05-21-2008 | 11:20 AM
Registered User
Fastest way is to pull the top cap off and fill it up. Drains alot faster that way too. Then top off the reservoir. The inside tank is more of an expansion tank than anything else.
Chris Sunkin is offline
Old 05-21-2008 | 11:22 AM
Hey just found screw all the way up buy the top cap LOL.
I like the idea of pulling the top cap and filling that way great idea thanks everyone.
Mike
Old 05-21-2008 | 01:46 PM
Wally's Avatar
Were doomed!
DONT FILL THROUGH THE TOP CAP!!!! the drives must be filled from the bottom up!!! you fill it from the top and you will trap and air bubble in there.....then when you go to run it the air will either airate the ail or work its way to the top and you will be without oil coverage on the upper gears and that will = disaster!!!
-Wally
Wally is offline
Old 05-21-2008 | 02:16 PM
Registered User
I should have added this part- let it sit. If you need to use it this afternoon, pressure-feeding thru the bottom is the way to go.
Old 05-21-2008 | 07:10 PM
J-Bonz's Avatar
Few....... glad ya cleared it up for em.. We dont need trs getting a bad rap
J-Bonz is offline
Old 05-21-2008 | 09:07 PM
Thanks I took the top cap off and filled it slow while turning the prop. Took 3 quarts of fluid the sealed it up and put 1/2 quart in the resivor. I will check again before puting in the water. Thanks for all the help.
Old 05-21-2008 | 09:51 PM
Rookie's Avatar
don't always believe the dipstick in the resivior. I kept checking my dipstick but apparently the check valve was not working properly. clogged (the valve that does not allow oil to drain out of the resivoir when drive is pulled) I ran my top half dry and trashed my upper gears and housing. I now pull the cap and take a visual look.
I pull the top cap and then the bottom plug to drain. and always fill from the bottom with cap off.
Rookie is offline
Old 05-21-2008 | 10:24 PM
Registered User
I guess it's semi-obvious that the drive takes more than 6 ounces of oil, but that's all that will go in thru the top at any one time. It has to find its way down. I know- never assume anything.
