454mpi with procharger,misfire and black smoke >
Old 05-25-2008 | 09:40 PM
Default 454mpi with procharger,misfire and black smoke
i have a 1998 american offshore i bought last year.i put it in the water today and had a nice ride with it. i have 3 problems:
- the rear deck became all covered in black and i could see black smoke coming from the exhaust.
i felt the boat misfiring at low rmp...it is running very rich or maybe the misfire is creating the un-burnt fuel...seems like both mufflers are smoking black..even throught the back of the boat all over....i saw the black smoke out of the 2 mufflers.
am i running too rich or maybe not burning all fuel ,maybe a bad plugs or wires... any ideas ??
my water temp gage isnt moving at all... where shall i start ? where is the sender that contraols the gage on the dash ? i see where the t-stat is.. there is a single wire hoooked on top of it.. i tried removing it and played with it a little to see if that would send any kind of signal but nothing happened...
would appreciate help on these 2 items...
chevalcabre is offline
Old 05-26-2008 | 09:12 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
A few things...
What you have going on is a bit normal for a "bolt on" procharger set up..
They run cold if just put on a stock engine as they dont normally use a tstat.. Also they do run a bit richer than a stock set up on an otherwise stock engine. They do this to help keep the engine comustion temp down to help avoid detonation. An MSD box with a ECM reflash & a 2 bar map sensor can help cut down on the loading up & soot. Or The faster cheaper, but less effective route is a ATI signal conditioner. If you need any of the stuff I can get it drop shipped to you..
Jamie / Lakeside Restorations
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 05-26-2008 | 09:36 PM
i appreciate the help... so basically, i will never be seeing the gage move as it will be always sitting under 140 ??
as far as the soot, i will buy a good cleaner and clean it every time.... it runs very very nicely.... maybe i will look only into the misfire i feel it is doing..change the plugs and wires...cap,rotor...
Old 06-24-2008 | 09:10 PM
Misfire could be from just to much fuel.
How does it do once you get it aired out?
jeff1000man is offline
chevalcabre
Do It Yourself, Boating on a Budget
23
06-24-2008 08:27 PM
chevalcabre
American Offshore
3
06-14-2008 07:11 AM
chevalcabre
1
06-12-2008 02:23 PM
34scarab
2
10-11-2005 04:48 AM
Quiet Storm
21
07-01-2002 04:08 PM
