Prop for Baja 240 sport >
Old 05-27-2008 | 08:45 AM
Default Prop for Baja 240 sport
I have a 1988 Baja 240 Sport with a rebuilt 454 bored to 468cu in with a roller valvetrain and Bravo 1 outdrive with 1.5 ratio. It came with a 3 blade Mirage 23 pitch prop. I have had it up to 64mph on GPS at 5000 rpm. Sometimes the prop will cavitate for no reason, I will be cruising along about 3000 rpm and the boat will drop and slow down. Any ideas what causes this? Any ideas about a new prop, what should I get? I have a quicksilver 23 pitch cleaver, it does not seem to change the performance any.
KBondra is offline
Old 05-27-2008 | 10:39 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Cupping the prop more should help to stop the problem. Otherwise, a 4 blade prop will carry a load better.
[email protected]
bbladesprops is offline
Old 05-27-2008 | 05:51 PM
sounds like your drive is to high try the drive all the way down if it stops then move drive up till cavitate then go a little . if you have it up to high it lose it grip
bajabob is offline
Old 05-27-2008 | 07:49 PM
Get the prop cupped to Mirage Plus specs and then labbed to regain the lost rpms. Your rpm and speed is right on for about a 425hp engine.
Griff is offline
Old 05-29-2008 | 05:15 PM
Do you think I should get a 21 pitch prop?
KBondra is offline
Old 05-30-2008 | 12:56 AM
No, get the 23 cupped and labbed. You should pick up a few mph and better bite.
Griff is offline
Old 05-30-2008 | 05:40 AM
Where do I get the 23 cupped and labbed?
KBondra is offline
Old 05-30-2008 | 07:20 AM
Default 240
blades 920 295 4435 would be close to you.
tony manzella is offline
ippon
3
07-10-2006 08:24 PM
dsmdude
04-17-2006 10:25 PM
Russ G.
04-02-2005 08:59 PM
khadley
02-05-2004 08:48 PM
khadley
Baja
0
02-04-2004 06:25 PM
