Pro Chargers and computers >
Old 05-31-2008 | 02:53 PM
trc2's Avatar
scarab
Default Pro Chargers and computers
If you do the stage one 5 psi pro charger on a pair of small blocks do you have to redo the computers or no do you gain any more performance out of them by having them redone has any one else done the pro charger kit on a 29 scarab with twin 350's Thanks guys
trc2 is offline
Old 05-31-2008 | 06:34 PM
Whipple Charged's Avatar
You certainly should. Where you located?
Dustin
Whipple Charged is offline
Old 05-31-2008 | 07:12 PM
trc2's Avatar
scarab
East coast Maryland
trc2 is offline
Old 06-01-2008 | 01:54 PM
Who will re tune them? I have a 383 and a procharger with a motorolla computer and I was told no one could tune them.Any help?
crowntow is offline
Old 06-02-2008 | 10:34 AM
check with cathouseperformancemarine.com they are knowledgeable with procharger applications
scarabsc is offline
Old 06-02-2008 | 11:16 AM
Procharger gets away with not reprograming the computer by using a multi step regulator to raise fuel pressure. It is usually pretty close on the top end. The problem comes in at idle and part throttle. Most, if not all, will run rich in these areas. This will generally soot up the transom. Although it won't hurt anything, it is annoying.By having the computer done, you will wind up with a much better running and driving engine. I will not install a Procharger without doing the computer. Which computer do you have?
Eddie
Young Performance is offline
Old 06-02-2008 | 11:55 AM
Pwrbt33's Avatar
Hey Eddie,
Thanks for the help with Bills Nortech! I am heading over there tomorrow. I'll let you know what I find out with the no fuel pump running!
John Smith
JAWS Marine
Pwrbt33 is offline
Old 06-02-2008 | 12:18 PM
ZXXX Donzi's Avatar
I ran a Procharger for a while without having the computer reflashed. It ran fine up top but stumbled around at idle and midrange. I highly recommend getting it reprogrammed.
ZXXX Donzi is offline
Old 06-02-2008 | 01:13 PM
tssteph's Avatar
Pro-charger says you do not have to. Mine ran fine without it but like stated above the transom was black. I had mine done by Mark at Percision marine. It ran a lot cleaner when I got them back. as I understand there is probably no difference in top end though.
tssteph is offline
Old 06-02-2008 | 04:23 PM
We recal the motorola on our kits, so maybe I can help you out if your having issues. email me at [email protected].
Dustin
