Lenco trim tabs >
Lenco trim tabs
Lenco trim tabs
Old 06-01-2008 | 02:30 PM
Default Lenco trim tabs
I'm looking to upgrade from my 12 x 12 insta-trim tabs to something a bit more substantial, and was wondering if anyone has run the new Lenco "high performance" tabs...
Thanks,
Doug
Boatally Insane is offline
Old 06-01-2008 | 03:23 PM
288sunny's Avatar
Emerlad Coast PwrBt club
Default tabs
My buddy has those tabs on his boat right now, he really likes them and hasnt had no trouble that im aware of.. The polish doesnt hold up as well as i would like, but we boat in salt water which may be part of it, it might be worth it to powder coat them?
I have thought about getting rid of my bennetts for those just not sure how much work it would be?
288sunny is offline
Old 06-01-2008 | 03:55 PM
Barrydet's Avatar
Default Lenco tabs
I used that same Lenco model to replace the smallish bennetts that came as original equipment on my previous formula 312. They worked just fine and proved to be a worthwhile upgrade. The installation was not difficult as the components are "plug and play". I purchased mine by phone/mail from a Lenco dealer in Florida....barryd
Barrydet is offline
Old 06-01-2008 | 04:38 PM
hoozeyurdaddy's Avatar
how has the electric motors held up under water? has there been many problems with that?
I've never installed a set on a customers boat, but if they are as dependable as bennett or boat levelers, I would try a set.
hoozeyurdaddy is offline
Old 06-01-2008 | 06:50 PM
Barrydet's Avatar
Default Lenco
I had zero difficulties with them. The electrics are completely sealed and waterproof. I routed the one control wire through an existing Bennett mounting hole. The tab mounting bracket also lined up with the Bennett mounting holes. I did not have to drill any fresh holes.
Barrydet is offline
Old 06-01-2008 | 07:16 PM
Thanks for the replies..
My biggest concern now is if my steering cylinders are going to be in the way....
Doug
Old 06-01-2008 | 07:31 PM
Barrydet's Avatar
Default Lenco
I had similar thoughts....moving from a 12" bennett to a 25" Lenco. If you turn the wheel hard over either direction, you will bump the drives against the tabs. I remedied that fact by not letting anyone else steer the boat. I had to make a mental note to myself to never turn the drives to far over. For manuevering purposes, I always remembered "drives straight, work the shifters". After I installed the tabs, I even bolted anodes to the mounting rails---very clean.
Barrydet is offline
Old 06-01-2008 | 07:33 PM
Barrydet's Avatar
Default Lenco
I just realized you are just down the road from me. I am at Cedar Park!!
Barrydet is offline
Old 06-01-2008 | 08:25 PM
I just replaced my 12x12 insta trim tabs with 14x19 Lenco Hi Perf tabs,Iam very happy with them!!they work great.
and I have no issues with the drives hitting the tabs
Attached Thumbnails Lenco trim tabs-picture-149.jpg   Lenco trim tabs-picture-151.jpg
boatnt is offline
Old 06-01-2008 | 08:32 PM
I also did not buy the LED switch/indacator from them,I reused my original rocker switches and added mechanical indicators.
Stainless Marine makes a kit to fit Lenco tabs
boatnt is offline
