Where to dump water? >
Old 06-01-2008 | 08:08 PM
Dock Holiday's Avatar
Charter Member #34
Default Where to dump water?
I'm building some new blower motors and trying now to get all the rigging lined up. Do you guys prefer to dump the intercooler water out the side of the hull or out the back through the transom and why?
I'm leaning toward the transom just for a cleaner look.
Thanks in advance for your replys.
Dock Holiday is offline
Old 06-01-2008 | 08:14 PM
Biggus's Avatar
Mine are dumped out the transom
Biggus is offline
Old 06-01-2008 | 08:18 PM
Just finished installing my intercoolers and wondering about the same. About to drill holes for the discharge. Would really be cool to use for the drive showers but wouldn't be able to see.
ciaoderhead is offline
KNOT-RIGHT's Avatar
I ran mine out the sides. Mainly cause the holes were there
However It gives you the ability to lean over and know your spewing water.
KNOT-RIGHT is offline
Old 06-01-2008 | 08:25 PM
Expat's Avatar
after having both, i would choose the side so you can take a quick look for your water flow.
Expat is offline
Old 06-01-2008 | 08:44 PM
DO IT ON THE STARBOARD SIDE! Just a quick glance back there and you can see the water flow, I check mine all the time. You will just have to get used to people telling you that your bilge pump is running
Plane Silly is offline
Old 06-01-2008 | 08:48 PM
Turbojack's Avatar
Out the side. I always look over the side and see the water coming out. If you dump out the back do it over the outdrive. Just a little more water to cool the drive
Turbojack is offline
Old 06-01-2008 | 09:18 PM
IGREE
DareDevil is offline
Old 06-01-2008 | 09:20 PM
obnoxus's Avatar
Charter Member #1171
use them for drive showers
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-01-2008 | 09:22 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I'd go with straight up; out the top of the gunwales.
That way, you will look like a pair of Yamaha PWC coming down the lake.
Sydwayz is offline
