my flex line is siezed into the trim cylinder.... >
Old 06-02-2008 | 12:20 AM
Default my flex line is siezed into the trim cylinder....
alpha.....changing a bunch of them......been a battle but got three of them changed ok......on this short one the line wrench just slipped......it goes into the topside of the cylinder.....any tips?
pullmytrigger is offline
Old 06-02-2008 | 06:49 AM
Airpacker's Avatar
Heat the fitting with a pencil tip torch and use vice grips or cut the line off and use a socket on the hot fitting Doug.
Airpacker is offline
Old 06-02-2008 | 06:55 AM
hunster's Avatar
Like air packer said. Next time use a flare nut wrench.
hunster is offline
Old 06-02-2008 | 09:57 AM
I'll try the torch.....I am using a flare nut wrench
Old 06-02-2008 | 11:47 PM
gotcha' you little b*tch.....!!
cut the line off and used a five sided socket....no heat reqd
Apack - Sean......did any more of your parts arrive??......you hitchin' a ride for Ray's run...???
Old 06-03-2008 | 01:47 AM
Cut line as said. Use a craftsman "bolt out" socket. Use some PB blaster first as well.
Griff is offline
riski bidness
3
09-13-2004 04:31 PM
migara422
2
08-19-2004 10:30 PM
Twig111
2
08-17-2004 08:05 AM
outlawinil
02-14-2003 10:16 PM
28SS
1
04-23-2002 06:45 PM
