V6 Ignition Module
Old 06-02-2008 | 04:07 PM
Default V6 Ignition Module
What is the part number for the V6 ignition module for the TB IV that has 14 degrees advance?
Shawn
shawn is offline
Old 06-02-2008 | 04:22 PM
Biggus's Avatar
Merc V6-14 ignition module #15247A1
Keep in mind that when installed on a V-8 engine, it only provides about 8-10 degrees. Also starts advancing at 650 rpm
Biggus is offline
Old 06-02-2008 | 10:09 PM
rbtnt's Avatar
Here is a link to a chart with some of Mercury's modules.
http://www.mtboats.com/mercuryigniti...cemodules.html
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 07-11-2008 | 02:32 PM
Anyone have one for sale?
shawn is offline
Old 07-11-2008 | 03:02 PM
tssteph's Avatar
I would assume that this could result in some stalling problems when going into gear. If it normally idles at 900 rpm and when dropped into gear it drops to 650rpm the timing is retarded several degress making it harder to idle. Correct?
tssteph is offline
Old 07-12-2008 | 08:51 AM
I am running a total of 34 degrees and do not have any problem with stalling, or starting.
shawn is offline
Old 07-15-2008 | 08:15 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
I have a used one. Was working fine. But I wanted new units. In fact, I have two used V6-14. I sold the third to somebody here a while back.
Let me know if you are interested.
waybomb is offline
Old 07-15-2008 | 08:36 PM
CcanDo's Avatar
Shawn, only for verification, the purpose of the v/6 module is to allow more initial timing with the same final numbers you have now. In other words, if 34* is to be the final then the initial would be 18*+/-. The V/6 module is generally used to create better starting and stronger idle.
The V/6 module may cause more load on the starter,cables and battery. In fact, the cables may require up sizing.
Good Luck
CcanDo is offline
Old 07-15-2008 | 09:43 PM
Waybomb, I just put on my second new one, but would like to have working spares on the boat. Please let me know how much you want for both spare units.
CCando, the main reason I use them is the fact that they do not have a rev limiter built into them, thus I can spool my motors up to 5800 or so. My engines make their best power at higher RPMS.The initial timing is academic. My engines start with the tap of a key and idle like car engines. They are pretty tame.
shawn is offline
Old 07-16-2008 | 05:12 PM
waybomb's Avatar
Contact me at waybomb at hotmail dot com.
waybomb is offline
Wanted
1
07-22-2008 04:06 PM
tjsmk8
5
07-23-2007 08:03 AM
TROUBLE MAKER
15
07-28-2004 07:00 PM
tmthunder
2
04-18-2004 06:19 PM
US1 Fountain
6
05-27-2002 11:32 PM
