Holley question >
Holley question
Holley question
Old 06-03-2008 | 07:47 AM
randy carlson's Avatar
Default Holley question
Fired up my fresh engines last night, had a few backfires before first runs, one engine running good, other acts very rich- from idle all the way up to 3000 would a blown power valve cause this ? If I remember correctly I should be able to look in carb and see extra fuel pouring in? first time around Holley's. Randy
randy carlson is offline
Old 06-03-2008 | 07:49 AM
Very possible on older holleys. Newer ones had anti backfire check balls I believe.
kennyo is offline
Old 06-03-2008 | 11:36 AM
Sounds like a blown powervalve to me also. Also check your fuel bowl levels. They could be set to high and are dripping fuel.
Griff is offline
Old 06-03-2008 | 12:52 PM
BDiggity's Avatar
i had same symptoms on my carbs after i had a big backfire. ended up having 2 blown powervalves. after we got them changed, everything ran great.
BDiggity is offline
Old 06-03-2008 | 03:11 PM
ENFORCER24's Avatar
If you have fresh engines in the boat its probably time to put a couple of kits in the carbs anyways , even the cheap kit for my holley had a pair of 6.5 power valves , even tho my carb only uses 1 power valve
ENFORCER24 is offline
Old 06-04-2008 | 07:24 AM
while idling you should not see any fuel dripping in, if you do ck float level(site plug side of bowl) or trash in needle & seat, if thats ok, pull the fuel bowls & metering blocks, look at the diapham of the power valve, if it's wet it's blown, may have 1 or 2 if it did blow and if its a older carb by a power valve protection kit and install with the new power valves. set float level so fuel right at bottom site plug, good luck, Rob
ezstriper is offline
Old 06-04-2008 | 07:32 AM
Sounds like a blown powervalve to me also. check your fuel bowl levels. Sounds like they are set to high and are dripping fuel.
Old 06-04-2008 | 08:46 AM
cigrocket's Avatar
Power valve, I had this on an HP500. Easy fix
cigrocket is offline
Old 06-04-2008 | 09:31 AM
Thanks Guys, swapped carbs last night to verify, it is carb, pulled it apart this morning blown power valve and trash in secondary needle seat. put a kit in it and heading home to see if I cant get her in the lake a bit this afternoon Randy
Old 06-04-2008 | 12:04 PM
Set the float levels with the boat in the water. The angle of the carb changes with it in the water compaired to the trailer.
Griff is offline
34Mach1
03-26-2008 01:50 AM
miamioffshore
10
03-22-2007 07:55 AM
Cigret1
6
08-02-2006 08:35 AM
hpy540
15
12-26-2005 11:04 AM
crmax
3
01-27-2004 04:28 PM
