24SE engine compartment volume >
Old 06-04-2008 | 12:26 PM
Nicolasticity's Avatar
Default 24SE engine compartment volume
What is the cubic feet volume of the engine bay on a 24ft Pantera -Im planning on fitting an auto fire extinguiher and would like to know if 100 cu ft is enough?
Nicolasticity is offline
Old 06-04-2008 | 05:24 PM
I think you can do L X W X H
tomcei is offline
Old 06-04-2008 | 05:28 PM
bouyhunter's Avatar
I'm just thinking about my engine compartment (seeing as that's where I've been spending a lot of time lately - motors out and I'm cleaning it up and re-rigging).
Gotta figure:
Beam - 6'6" to 7'
Length - 4' to 4'6"
Depth at keel - max 4'
I'm thinking max 126 CF - and that isn't taking into consideration for the 24 degree deadrise.
I think your 100 CF is probably about dead-on.
Mind you, this is just a quick calculation off memory and approximation, but I think you'd be pretty good with the 100.
bouyhunter is offline
bouyhunter's Avatar
I was calculating and typing while you posted Tom.
Old 06-04-2008 | 05:34 PM
this is something you could go over kill on and feel good about it.
It would be an easy sell to the wife
tomcei is offline
Old 06-04-2008 | 05:53 PM
bouyhunter's Avatar
You're right, it would be easy to go over-kill on this one.
But, if budget is an issue (as it would be in my case), I would imagine these are already rated at an "over-kill" rating.
I'd spend the additional money elsewhere - unless it would look cooler
But, that's just me.
Old 06-04-2008 | 05:56 PM
duunoit's Avatar
The motor is probably about 3x3x3 so there goes another 27ft^3
Does anyone else think that blocking off the rest of the boat would be a good idea (just in case)?
duunoit is offline
Old 06-04-2008 | 06:12 PM
bouyhunter's Avatar
You're right.
I wasn't even taking the motor, transom assy, batteries, etc... into account.
Blocking off the area between the bilge, and under the cockpit/down the gunwales raises another good point.
Before this turns into over-analyzing this like what would happen in a GD thread, I'll just say I'd feel comfortable with the 100CF without blocking off anything.
Old 06-04-2008 | 11:07 PM
Elite Marine's Avatar
I can get them pretty reasonable. Pantera owners discount!!
Kirk
Elite Marine is offline
Old 06-05-2008 | 01:31 PM
Kirk
thanks, cost here is £239 for a 100cu ft Seafire - Fireboy even more!
Need to get it for next weekend so I dont recon its going to be practical.
