cleaning eng oil coolers for new engines >
Old 06-08-2008 | 06:19 PM
Default cleaning eng oil coolers for new engines
im dressing my new engines and want to clean the lines and coolers,the way ive cleaned everything before was to flush them in the solvent/parts wash tank,,does this get them clean enough ??
dmaxx3500 is offline
Old 06-08-2008 | 07:12 PM
What type of coolers?
THRILLSEEKER is offline
Old 06-08-2008 | 09:13 PM
oil coolers that mount in the bellhousing merc style
Old 06-08-2008 | 09:16 PM
I don't think a solvant tank could clean a cooler properly. To do it right the end caps need to come off. Solvant tank woulden't have enough pressure. I take all my coolers to a rad. shop. They take the ends off and re-braze them back on.
Westcoast is offline
Old 06-10-2008 | 10:37 AM
I just bought new bellhousing coolers from CP. After seeing the internal construction I think it would be very hard to flush theese things very well.
Old 06-10-2008 | 12:19 PM
If you are cleaning it because you trashed an engine I will tell you from experience to throw it in the trash can. I thought I cleaned one out after spinning a bearing, and the next engine lasted 10 hours. I tore the old one apart to see exactly how they are built. I like saving money just like the next guy but that is one area I would not skimp on. I also replaced all the hoses after my expensive lesson
1BIGJIM is offline
Old 06-10-2008 | 12:24 PM
If you trashed an engine, throw the cooler away or take it to the scrap man and get your money for the copper. If the engines were OK when you tore them down, then you can clean them.
Good luck
jeff1000man is offline
Old 06-10-2008 | 03:04 PM
Full Force's Avatar
Same here, I spun a bearing last year and flushed my coolers, at the time I did not know how they were on the inside, well... 1 hr on new engine and a spun bearing due to crap going through the engine, i fould a couple things it could have been, the cooler is one of them.
I agree, if the engine did not have anything in oil the cooler should be flushable, if it had crap in oil, toss it.
Full Force is offline
Old 06-10-2008 | 03:05 PM
Full Force's Avatar
Here is a pic of the small inners, I tried the best i could, they are like little 1/8 inch honeycombs, never get them cleaned out..
Old 06-10-2008 | 03:08 PM
Good luck
Great now the Meth Heads will be stealing oil coolers for copper. We just got our water back on at our dock because they cut six feet of copper pipe from the shore to the docks.
1BIGJIM is offline
