Tow weight calculation?
Old 06-09-2008 | 12:14 PM
Default Tow weight calculation?
Is there some formula to use to determine total weight for towing? Or is just the weight of the boat plus the weight of the trailer?
bert4332 is offline
Old 06-09-2008 | 12:26 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
All boat weights are dry.
So weight of boat +
Total actual weight of trailer (nothing to do with its rating).
+30-50 lbs. per battery.
+8 lbs. per gallon of water (fresh water, waste water)
+6 lbs. per gallon of fuel
+tools, fenders, ropes, lines, ANCHORS, etc. etc.
(remember the spare tire and anything in the trailer tool box adds in too)
It adds up FAST!
Remember, your passengers, coolers, ice, tools, spare tires, jacks, etc. etc. all adds into your GCWR (Gross Combined Weight Rating) of your vehicle as well. If you load up your tow vehicle with all of the aforementioned in this paragraph, you DECREASE the amount you can tow by that much as well.
Sydwayz is offline
Old 06-11-2008 | 10:17 AM
czy40p's Avatar
Find a scale! Truck stop, grain elevator, salvage yard, gravel pit, might even find one at a landfill. Should not be more than $20. I dropped mine from the truck, but you could do the combined and then go back and weigh just the tow vehicle. It just takes all the guess work out, and all the posted numbers always seem off, dry weight does not even come close to actual trailer, fluids and gear. I think my dry weight was 4,200 LBS and the boat with fluids (Minus the drive) and trailer, no gear was 7,200 LBS.
czy40p is offline
fastlane40
Prop Talk
19
08-28-2007 12:51 PM
TeamSaris
13
01-03-2007 09:46 PM
1BIGJIM
2
06-07-2006 04:48 PM
NJDave
6
06-15-2004 12:41 PM
Hot Boat
19
07-28-2002 08:58 PM
