Go Back  Offshoreonly.com > Owners Forum > Excalibur
1979 27 Excailbur >
1979 27 Excailbur
1979 27 Excailbur
Old 06-11-2008 | 02:16 AM
carter38's Avatar
Default 1979 27 Excailbur
I just had a guy drop one off to have the motor pulled. I have never seen this kind of setup before. How does the rear of the motor mount in the early trs's the ears from the gimble plate are not being used.
carter38 is offline
Old 06-11-2008 | 08:29 PM
CIG3's Avatar
The trans plugs into the gimbal. There is and expansion ring in the tailstock to hold it in place. Front mount placement is critical.
CIG3 is offline
Old 06-12-2008 | 01:38 AM
carter38's Avatar
So does it just slide in or bolt in? It just has regular mounts in the front bravo style not race mounts.
carter38 is offline
Old 06-12-2008 | 12:55 PM
CIG3's Avatar
Pull the drive and look into the gimbal. You will see the alignment spring and then the flange that will have a series of 3/8 nuts that expand the expansion ring. loosen them and then pull the front mounts. The engine will have to go forward 4-5 inches to clean the inner transom plate.
Make sure when you re-install the engine and trasn that you check the alignment.
CIG3 is offline
b-rad
08-22-2008 09:06 AM
overdrive75
Excalibur
16
09-20-2007 07:05 AM
B251
06-23-2007 12:02 PM
Stormrider
Pantera
1
06-23-2006 12:16 PM
THE BULL
Sonic
0
04-25-2002 07:28 PM
