Bonding USCG plaque to the Hull, what type glue?
I have a new USCG plaque from Bernard engraving to bond to the hull inside the bilge. Bernard suggested to epoxy it since it is required to be a permanent mount. The plaque is 19" x 4" x 1/16" thick plastic and of course the hull inside is white gelcoat.
I don't have much experience with epoxy and don't want epoxy glue running out from under the plaque as it's drying.
Any suggestions on type of epoxy and how to keep the stuff from running down the hull side?
I've also considered 3m automotive molding tape, but that won't be exactly permanent.
Is that the plaque that says not to dump oil over board? I removed mine while redoing the boat and lost it.Now I hear its a big fine if you dont have it so I need to know where to get one.Also in the body shop we would use a row top and bottom of the automotive moulding tape and you would have to rip the bulkhead off to remove the plaque.
Thanks Anthony
Thanks Anthony
Thanks Anthony
The USCG informational plaques (required by law for all boats) can also be ordered from Bernard at the link below. The top 2 are required for boats longer than 26'. They are plastic and much better looking than vinyl ones from other boating supply stores. I used the 3m auto tape for the oil discharge plaque to adhere to the bottom side of the bilge hatch and it hasn't budged.
Bernard Engraving Corp.
Hi Anthony, the plaque I'm refering to is one that is required of USCG documented vessels and has 3" numbers engraved for the document number assigned to my boat. The requirement is that if this plaque is attempted to be removed it will leave obvious evidence of tamper on the inside of the hull and break.
Thanks for the link.I just ordered my plaque.
Thanks Nordic95
waterboy222
Detailing, Painting, & Fiberglass
3
06-13-2007 09:31 PM
