Any reason  a new engine would have less break in oil? >
Old 06-13-2008 | 05:50 AM
Default Any reason a new engine would have less break in oil?
Heres the scoop. I had a pair of new 383s built from a local very reputable engine builder, they have been ran and broken in in his shop. Last night I drained the break in oil and there was only 3.5 qts in one and a tinge over 3 qts of oil in the other. Is there a logical reason for not completely filling theese things for break in?
THRILLSEEKER is offline
Old 06-13-2008 | 07:33 AM
Registered User
None whatsoever. I would be on the phone to him immediately.
What do the plugs look like?
Chris Sunkin is offline
Old 06-13-2008 | 08:03 AM
Maybe the wrong dipsticks?
JRider is offline
Old 06-13-2008 | 08:27 AM
Registered User
Let's assume the engine builder can count higher than three. You'd expect the guy to notice that the number of bottles on the floor wasn't enough. The oil went somewhere- and even new bores shouldn't use several quarts on the test stand. way loose intake valve stems with no seals installed would gobble up a bunch of oil.
Old 06-13-2008 | 11:17 AM
I talked to him about it and he said he originally filled both engines with 4 qts+12oz cam break in lube. He said he lost some during initial priming, and a little run time with the valve covers removed. He says the rest is in the filter....
Old 06-13-2008 | 12:29 PM
If they are standard pans, the motors prob. only hold 5 qts. The filter will hold almost a quart, depending on what filter it is. I would not make such a big fuss over it myself. Just make sure you fill them to the proper level and run them!!
DKerns is offline
Old 06-15-2008 | 06:55 AM
and it doesn't matter anyway... no side loads on the test stand so oil pick up was plenty deep enough in the oil... no sweat
stevesxm is offline
nocigarette
29
05-11-2007 06:19 AM
Ca$hed Out
03-26-2007 09:46 PM
Pat McPherson
1
05-05-2005 07:42 PM
lucky strike
20
03-06-2004 06:02 PM
