496 ho plug wires are $500!!! Please read
I just bought a 26ft cat with a 496ho...still trying to dial everything in. with 4 passengers I am turning 4500 rpm with a 26p, bravo 1x, 1.5 gears and getting 65mph. My plans were to install headers and lab the prop. When I was installing the headers I noticed a ripped boot on one of the plug wires. This could have been there already or I may have done it when installing the headers.
I have a few question...please help:
could this wire problem cost me 400rpm?
Could I repair the rip in the boot..if so how?
Is there anything special about these wires since they cost $500 for the set from merc?
can I use aftermarket wires like MSD marine?
Could this wire problem cost me 400rpm?
Possibly.....But....have you heard the motor running crappy? Is the wire/s really having an impact? In reality if the connector has contact and delivering spark without arc, there shouldn't be a problem. In a pinch if so, wrap electric tape arouund the boot to prevent arc.
See above.
Wow...I doubt it...Honestly why would the need be any different than the automotive version in terms of coil to plug demand?? Remember, if it's got marine associated with it, the price jacks up. Volts to plug is simply volts to plug.
Can I use aftermarket wires like MSD marine?
Maybe you can replace the one bad wire with a Vortec truck 496 (8.1L) wire????? since the bottom line is delivering the appropriate voltage to the plug which I'm sure is no different than the truck version, in theory why not????
I'm no expert, but is my logic askew?
See above.
Don't know about the 496 but I tried to get away from paying $500 for a set of Porsche 911 leads and purchased the 'best' aftermarket I could find. The engine wouldn't even idle. Paid the $500 and running smooth and hitting the redline effortlessly.
$430 at mercruiserparts.com
What a rip off. I'm headed outside to look at my boat and truck now, I'm willing to bet the GM 8.1L wires are the same. Then you could also just buy 1 wire.
[img][/img]
[img][/img]
Nope, not the same as the truck wires. The Merc wires are much longer to go around the exhaust. You might be able to get them at a GM dealer though. The wires on my motors say AC Delco on them.
[img][/img]
[img][/img]
