Baja 90 mph club >
Baja 90 mph club
Baja 90 mph club
Old 06-14-2008 | 04:35 AM
articfriends's Avatar
Default Baja 90 mph club
This was mentioned on another thread so I though it would be interesting to start a thread. If you have a Baja that breaks the 90 mph mark please post on this. A pic of your gps (if possible) model of boat,size of engine and hp,gear ratio/prop you were turning and rpm would be useful too,Smitty
2000 Baja 272
540 cubic inch procharged w/1057 hp/1009ft lb tq pulley on 93 octane
32 pitch labbed merc 4 blade turning a little past 6000 rpm's w 1.50 rato drive
98-99 mph (hand held gps also read 98 on trip recall)
articfriends is offline
Old 06-14-2008 | 04:37 AM
Same boat running less boost (1037 hp/971 ft lb tq pulley) turning 32 pitch 5800 rpm's (95 mph),Smitty
Old 06-14-2008 | 08:11 AM
TEAMBAJA's Avatar
2000 Baja 272
At first glance that gauge makes it look like your well over 100 mph!
TEAMBAJA is offline
Old 06-14-2008 | 09:29 AM
JasonSmith's Avatar
92-93 MPH
1999 29 Outlaw, 454MPI's, Whipple 2.3's, 8 lbs of boost, labbed 30 Bravo 1's on IMCO -3" shortys, 1.34's gears & IMCO extension boxes.
JasonSmith is offline
Old 06-14-2008 | 10:07 AM
2002 33 outlaw, Decolite, 575SCi's, Stellings
boxes 1.5 XR's, 32 pitch labbed maximus's.
So far, they only let me in the club before June and after August
JaayTeee is offline
Old 06-14-2008 | 01:45 PM
When I made that run the boat was climbing out of the water pretty high riding on pretty much just the drive so I had a death grip on the wheel and was just taking quick glances at the fuel and oil pressure. When I stopped and hit the recall I thought it read 109 myself for a few seconds then I looked closer and reality set in,after all I was only turning 3 hundred rpm's or so more than the 95 mph run,Smitty
Old 06-14-2008 | 08:12 PM
We got a 2000 Outlaw 33 with twin 540 Bulldogs 500hp... We've got it up to 83mph in some mild choppy water...This winter going to be upgrading the heads on the engines and hoping to be able to be right where you are...We also have the stellings extension boxes on as well but running 29P P5X Hydromotives...
lbzmotofmx is offline
Old 06-14-2008 | 08:22 PM
jeff32's Avatar
small club indeed!
jeff32 is offline
Old 06-15-2008 | 01:00 PM
I hope to be in here in a week or two. Hell I'd settle for the 86 I had last year!
kennyo is offline
Old 06-15-2008 | 08:48 PM
Smitty's Avatar
I hope to be there in a few weeks as well. We'll see if the new motors have what it takes. If not then bigger superchargers will be on the Xmas list !!!
Smitty is offline
