4 Blade I.o Prop On Outboard ? >
Old 06-15-2008 | 12:37 AM
Default 4 Blade I.o Prop On Outboard ?
Can I run a 4 blade Hydromotive bravo prop on a new 300 Opti ?? I would normally be goingt to run a 32 three blade . I think the lack of vent holes will not be a problem , what do the pros think ? The reason I ask is that I have a like new 30 pitch 4 blade in box .
Larry
activatorf1 is offline
Old 06-15-2008 | 07:24 AM
t500hps's Avatar
21 and 42 footers
Don't know much about OB but my father has run bass-boats since I was born and has been running 4 blade props for years. For him, hole shot is better, topend doesn't sufer much.
t500hps is offline
Old 06-15-2008 | 06:49 PM
rchevelle71's Avatar
I run a Revolution plus on my 225, no problem, so long as you have the power to turn it.
rchevelle71 is offline
Old 06-16-2008 | 12:40 AM
Thanks , but your missing the point , I'm in hurry to Drive my 32 Skater , 300 Opti's will be here soon and I have a new RH 30 Bravo 4 blade from my race boat , will this prop fit shaft and clear gearcase ?
Larry
Old 06-16-2008 | 06:46 AM
Thunder1's Avatar
I am presently running 4 blade 26" Bravo's on my Opti's and they work just fine with no issues, but they are only 225's... Hope this helps!
Thanks, Karl
Thunder1 is offline
Old 06-16-2008 | 08:35 AM
Is the lack of vent holes an issue ?
Old 06-16-2008 | 01:05 PM
Thunder1's Avatar
Not an issue... The application is a 34 Fountain with Trips and a fairly high X demension... Was the chase boat for Rio Roses a couple of years ago and the props work just fine although it did come with 24's on it... I would think you have it covered and best of luck!
Thanks, Karl
Thunder1 is offline
Old 06-16-2008 | 01:10 PM
The Fountain was an Outboard ?
Old 06-16-2008 | 01:17 PM
Have BBLADES put vent holes in the props.. They nailed the prop setup on our 28 powerplay with twin 300's. Labbed 28" bravo 1 4 blades with vent holes
cowisl is offline
Old 06-16-2008 | 01:24 PM
Thunder1's Avatar
Yup and still is...
Attached Thumbnails 4 Blade I.o Prop On Outboard ?-cambagn-r1-016-6a_edited.jpg
Thunder1 is offline
