New boat owner advice needed on drives... >
Old 06-16-2008 | 12:48 PM
Default New boat owner advice needed on drives...
Ok I just purchased a new to me 1985 Chris Craft Chris Cat, for those of you who are not familer with the baot it is the same hull as the American Offshore 31', with SSM II drives.
First off I AM A BOATER ON A TIGHT BUDGET!!! I try to do as much as I can on my own.
Here is my problem somewhare along the way the starbord drive was replaced and the boat now has 2 left hand rotating drives so at about 80 I am having some really bad torque steer.
The boat has SSM II's for drives, which I know are hard to find parts for, so what is going to be the most cost effective solution to my problem????
Thanks!!!!
bigo181979 is offline
Old 06-16-2008 | 02:39 PM
Biggus's Avatar
Konrad Marine has a bolt-on replacement for the SSMII.
It's called the PRS II conversion.
www.konradmarine.com
Biggus is offline
Old 06-16-2008 | 04:20 PM
I keep hereing this and that about the X-demension, and that if the drives are shorter or longer that changes it and that changes the attitude if the boat and so on, its got me all confused!!!
Aren't the Konrads Shorter then SSM II's
What would happen if I put on a normal TRS Drive on??? A buddy has a few extra sets!
Old 06-16-2008 | 04:25 PM
jryan26's Avatar
If Im not mistaken the speedmaster II has the same upper as a TRS.
jryan26 is offline
Old 06-16-2008 | 04:45 PM
Thats what I thought...
If that is true, the gears that make it a left or a right rotation, are they in the upper or in the lower???
Old 06-16-2008 | 04:48 PM
Biggus's Avatar
The SSM II is about 1" longer (.92") than the TRS. Yes, they do share the same upper and you can install TRS lowers on your SSM II uppers BUT, they MUST be shimmed to the upper. You can not just bolt on a TRS lower, it's got to be shimmed to the upper.
As for the Konrad conversion, the drive is fitted with a spacer kit to get the propshaft height where is needs to be.
Kurt
Biggus is offline
Old 06-16-2008 | 04:53 PM
Kurt
Well thats good to know, right now its not in my buget to put 2 new conrad units on, but I will keep that in mind for later. As far as shimming, where does it need to be shimmed and will putting an upper from a right hand unit with the lower I have (left hand drive)make it spin to the right?
Old 06-16-2008 | 04:54 PM
Biggus's Avatar
The rotation of the drives is determined by gear placement of the lowers.
Biggus is offline
Old 06-16-2008 | 04:57 PM
Ok so I will need a different gear set for the lowers then! That answers that part for me! As you can tell I am clueless when it comes to drives!
I guess I better find a new lower or new gear set probably not going to be easy either way!
Old 06-16-2008 | 05:16 PM
Ratickle's Avatar
Put the question in the drive forum about changing the rotation on your drives. There are a lot of guys with knowledge of the requirements on the site, it's just a matter of getting them to see your question.
Ratickle is offline
