502 Mag vapor locking??? >
Old 06-16-2008 | 02:21 PM
Default 502 Mag vapor locking???
i have a 97 outlaw with a 502 Mag....basically it runs flawless when i first start it up and run it cold....when i sit all day and go to leave it fires right up again but when i go to take off it sputters and wont plane out....i can throw it in neutral and it barely will idle...ive been pumping the throttle trying to clean it out and it usually will kill it....it does that a couple times (2-3 minutes) and then all of the sudden it will just fire right up and run perfectly again? It also doesnt do this every time, its sporatic but always after i run it and then sit for a while. vapor locking? fuel filter? anyone had this problem or ideas where to start looking?
will22 is offline
Old 06-16-2008 | 02:55 PM
BrettM's Avatar
Offshoreonly Advertiser
Commercial Members
Service bulletin 99-07, Pump booster kit 862264A4 will fix the problem. I can get you one if you need it!
Brett
BrettM is offline
Old 06-16-2008 | 03:11 PM
Talking
They can't run on just air!
kennyo is offline
Old 06-16-2008 | 03:43 PM
obnoxus's Avatar
Charter Member #1171
Yup,,, Ill bet you dont have the mechanical pump on your sea pump,,, Merc eliminated this for a short time.
If so ,,, install the kit mentioned above and all will be well !!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-16-2008 | 03:52 PM
Brett
thanks for the help, but what exactly is this booster kit fixing? is it vapor lock or some other gremlin?
will22 is offline
Old 06-16-2008 | 04:46 PM
I'm I smooth or what! Quit cutting your fuel with biodiesel!
kennyo is offline
Old 06-16-2008 | 05:10 PM
we all cant have those flux capacitors like you big balla...now get busy im trying to get a real answer...
will22 is offline
Old 06-16-2008 | 06:16 PM
BrettM's Avatar
Commercial Members
Yes, Vapor locking is the problem. It is quite common on the 454-502 MPI's. The fuel boils and creates a lock in side the fuel filter and the stock pump is not enough to suck it through. This pump is a secondary pump that creates the pressure to eliminate the lock!
Brett
402-464-4791
BrettM is offline
Old 06-22-2008 | 08:47 PM
eddie's Avatar
If you want to double check, spin your fuel/water filter off and check the level. If this is your problem it will be down 1/4 to 1/2 inside the filter.
The kit will fix this problem.
eddie is offline
Old 06-22-2008 | 10:08 PM
JasonSmith's Avatar
Get the kit. PBC can take care of ya!
Eddie can too, but in a different way.
JasonSmith is offline
