High Speed Pulling Empty Trailer=Tire Damage ? >
Old 06-17-2008 | 08:42 AM
Rage's Avatar
Default High Speed Pulling Empty Trailer=Tire Damage ?
I have a tandem axle for a 3700+ pound 25 foot boat that I would like to pull empty about 500 miles total @ ~70 mph. I am concerned that the the tires may suffer uneven wear from tire hop / bounce with the trailer unloaded which could produce uneven tire wear / cupping.
Anyone had any experience pulling an empty boat trailer under these conditions? Any tire issues as a result?
Rage is offline
Old 06-17-2008 | 09:19 AM
Registered User
The trailer should have enough weight to keep that from happening. You could always have the tires balanced, which is uncommon on a trailer.
You can always leave an hour early and drive 60 and probably have way less chance of any issue.
Chris Sunkin is offline
Old 06-17-2008 | 09:25 AM
That's a pretty heavy trailer...I wouldn't think hopping, scuffing would be that much of a problem. Like Chris said - driving a little slower and being aware of bumps (okay, every bridge/pavement joint) is helpful.
BlackJack58 is offline
Old 06-17-2008 | 02:00 PM
fabricator's Avatar
If the tires are balanced, they won't have the tendency to hop and set up an irregular wear pattern.
fabricator is offline
Old 06-17-2008 | 07:25 PM
scottc's Avatar
Lower the air pressure in the tires. Don't run them flat but maybe @ 25-30lbs. If they are high pressure tires (@50-60lbs) this will help. Just remember to reair them before you reload the boat.
scottc is offline
Old 06-17-2008 | 07:27 PM
Hook on to it and hammer down. You'll be fine.
Screamin' Seamen' is offline
Old 06-17-2008 | 07:31 PM
BUIZILLA's Avatar
instigator
virtually ALL *trailer service only* tires are advertised speed limited to 65 mph
BUIZILLA is offline
Old 06-17-2008 | 10:10 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Rut roe. US1 hasn't read his tires.
US1 Fountain is offline
Old 06-18-2008 | 09:13 AM
Rage's Avatar
Yes they are at 55 psi for the load so 30 psi should help a lot running empty.
Rage is offline
Old 06-18-2008 | 03:22 PM
