Check This Out....twin Trim Usa >
Old 06-20-2008 | 09:22 AM
Jassman's Avatar
Default Check This Out....twin Trim Usa
Guys a buddy of mine has this trim modulation system that he has put on a few boats over here in MS..Check the video out and see how if his system would work on you're twin or trip application...I can see some benifits but have not tried it myself as of yet. Joystick operation..very quick..helps in turns....check it out
www.twintrimusa.com
John Fraleigh
228-363-0805
Jassman is offline
Old 06-20-2008 | 09:31 AM
Sydwayz's Avatar
Forum Regulator
I don't really see the advantage for our type of boating. I personally do not like running the drives trimmed at different angles because I don't like the thought of the transom having a twisting force applied to it. On the Cat hull fishing boat; I can see some advantages.
Sydwayz is offline
Old 06-20-2008 | 10:21 AM
On the drives it seems silly. On the tabs I don't usually drag both and move one up one down... it's usually one down a bit and one up, or both dragging.
VetteLT193 is offline
Old 06-20-2008 | 10:24 AM
racer-x6's Avatar
Jeff,
I would not use this on a V bottom boat. it works ok on cat fishing boats. V boats lean into a turn and don't need the drives at dif. angles. Back when John was just getting started I went to his house and looked at this system lots with saftey concerns.
racer-x6 is offline
tkrivitz
0
07-13-2008 11:27 PM
Nauti Kitty
10-03-2005 08:56 AM
cooltoys61
Fountain
11
11-02-2004 05:33 PM
Marginmn
Fountain
15
05-15-2004 10:13 AM
SLINGSHOT
10-04-2002 10:56 PM
