What to look for on a 24 >
Old 06-20-2008 | 11:05 AM
Default What to look for on a 24
I've been searching the threads and have picked up some info but I am going to be taking a look at a 24' next week and would like to know what to look for.
It is an 81 with TRS and a 454 with heads it appears to have hyd steering.
Anything that I should be taking a close look at.
any idea on a fair offer price?? from the pics it looks to be in fair condition.
beck427 is offline
Old 06-20-2008 | 11:52 AM
rchevelle71's Avatar
All the normal stuff that can happen to any boat if not well taken care of, look for stresscracks, waetness in the transom, wet stringers. None of this is anything that specifically happens on a Pantera, but mine is a 1981 also, and had a hard life, it had a few defects when i bought it, but nothing major. Which boat are you looking at?? S/E, or Sport?? what power??
rchevelle71 is offline
Old 06-20-2008 | 12:09 PM
All the normal stuff - transom, stringers, stress cracks. I would carefully inspect the engine bulkhead (i.e. the wall that separates the engine bay from the cockpit). I would also carefully look at the gas tank and related plumbing. I haven't heard of pantera's having these problems, but poor rigging can lead to roted transom and stringers. All it takes is one fugtard mechanic.
TexomaPowerboater is offline
Old 06-20-2008 | 12:14 PM
We must have been typing at the same time
Yes, that bulkhead will tell ya if the tank has ever been removed, as it has to be cut to get the tank out, my '81 has an Aluminum tank(about 50 gallon), which has had no problems.
Old 06-20-2008 | 12:41 PM
thanks for the response....
Where exactly is the fuel tank?
it is a 454 and said to be 370hp.
beck427 is offline
Old 06-20-2008 | 01:42 PM
Fuel tank is under the floor centered between the stringers, runs from the backseat bulkhead to the front cockpit bulkhead Approx.
Boat should run around 65 with that setup.
Congrats
Old 06-20-2008 | 03:23 PM
anyone have a similar setup that can reccomend a prop. I'm looking for down the road, not even sure if I am going to purchase the boat but you know how it goes when you look at something to buy......
beck427 is offline
Old 06-20-2008 | 03:35 PM
Stormrider's Avatar
JC Performance Engines
Got any pics? if not, take some.
For that power a 23mir+ or a 24B1, depending on power.
Stormrider is offline
Old 06-22-2008 | 09:41 AM
alright don't give me too much sarcasm with this one....... how do I check the stringers and bulkhead???? do I poke them with something or just do a visual??
beck427 is offline
Old 06-22-2008 | 03:46 PM
If you want the boat then spend a little money with a survey.
This will keep you from spending alot on a bad deal.
tomcei is offline
