Spark plug for 454 Magnum Carb, NGK or Champion or ??? >
Old 06-23-2008 | 03:36 PM
Default Spark plug for 454 Magnum Carb, NGK or Champion or ???
2Slow4me is offline
Old 06-23-2008 | 05:29 PM
Biggus's Avatar
Ngk Br6fs
...edit, why when I type in all caps, it posts in lower case?????
Biggus is offline
Old 06-23-2008 | 07:24 PM
baja36ft's Avatar
NGK BR6FS,AC MR43T
baja36ft is offline
Old 06-23-2008 | 07:33 PM
GO4BROKE's Avatar
Ac delco or NGK, no champions. I won't even put them in my lawnmower.
[img][/img]
GO4BROKE is offline
Old 06-23-2008 | 11:00 PM
Just looked up NGK, the ones mentioned above.
And they also have Iridium, (advantage? Worth the extra $$??)
Iridium BR6FIX 2318 0.04
Standard BR6FS
P.S. My engine is a 1990, and a bit low on compression, and top speed and slow putting around are important to me,
2Slow4me is offline
Old 06-24-2008 | 12:46 AM
Delco MR-43T
Best marine plug out there!
Westcoast is offline
Old 06-24-2008 | 06:48 AM
hoozeyurdaddy's Avatar
I have had good luck with NGK, BR6FS will work fine, don't waste your money for iridium's.
Larry
hoozeyurdaddy is offline
Old 06-24-2008 | 06:41 PM
Hydrocruiser's Avatar
Arrow
The absolute worlds best plugs are Denso Racing Iridiums.
The A/C 43T = W 20SU Denso's
http://www.densoiridium.com/
They can handle up to 4,000 *F of heat. Used by NASCAR near exclusively.
Get 'em at www.Sparkplugs.com
Hydrocruiser is offline
ls1nova
16
05-15-2008 01:08 PM
snake plissken
07-15-2007 02:30 AM
zimm17
5
05-27-2006 11:02 PM
speed demon
3
06-29-2005 11:27 AM
97BossHammer
5
02-12-2004 02:57 PM
