My 540 lost some power...need some advice.
I have a dart 540 block w a tbs blower application (8lbs of boost), demon carbs and full msd ignition. I have 4 blade 30 pitch props, xr drives w speedmaster lowers and imco extension boxes.
Last year I was turning 5800-5900 rpms at WOT. First, I broke a drive and replaced both w the new style xr uppers. Second, I put some bad gas in and burnt up a piston. I completely freshened up that motor and at the end of last year I did the same to the other motor (freshened it up).
No one is sure of where the timing was set on the motors last year so we set them at 36 at 3000 rpm and at idle is 18.
My question is. I cannot turn the same rpms anymore. I can only turn about 5100-5200 rpms. Nothing has been changed inside the motors, blowers, or carbs. How am I losing 700-800 rpms? Could the timing cause this? If not, I would greatly appreciate any suggestions on where I should start looking.
thanks!
thanks!
Registered User
I'd start with a leakdown test on the engine, then I'd get an indicator on the rockers and look for a bad lobe. 36 is plenty of timing- if it's correct. I've seen pointers a few degrees off of TDC before. When you toasted the piston, I assume you had the whole thing apart- did you change anything on the cam? If you have a multi-position timing set, the cam might not be degreed properly. You may have been running it retarded an now are not. I misread a crank sprocket once and chased that one for some time- had NO power.
Registered User
sounds like to me you have WAY to much timing for a blower setup, you only need a max of 28 and about 15-18 initial, blowers like timing in low, and not under boost, unless you are running race gas you are going to take out another piston. what compression are you running ? even at 8-1 your static compression is over 12-1 at that boost, Rob
Chris.... I have lots more pics!!
Registered User
If it was too much timing, they'd be detonating and rattling like mad- and would probably destroy the pistons.
If you don't mind a 100 mile tow to Nashville, I know the guy who can make it sing. And probably keep it from a very expensive meltdown.
Way to much timing for a blower! You should be in the 27,28,29 area at full advance. We are all just guessing since the only way to find out how much timing is correct is to do a timing loop on the dyno. But we all can take an educated guess, from our own experiences.
