What Lube Do You Use On Your Shaft?? >
Old 06-26-2008 | 05:18 PM
Strip Poker 388's Avatar
Rob
Talking What Lube Do You Use On Your Shaft??
What do you use on your prop shafts?
Mercury 24C, Mercury Anti Corrosion grease or is there something better out there you all are using.
And no Sea Tow lube
Strip Poker 388 is offline
Old 06-26-2008 | 05:21 PM
KY and sea tow work good together , so I'm told !!!!!!!!!!!
Jeff P31 is offline
Old 06-26-2008 | 05:23 PM
Mercury special lube 101, its light green if your wondering.
MOBILEMERCMAN is offline
Old 06-26-2008 | 05:24 PM
I find astroglide works the best.
KrystalTransport is offline
Old 06-26-2008 | 05:35 PM
Old 06-26-2008 | 05:37 PM
Lmao
niceguy is offline
Old 06-26-2008 | 05:40 PM
NJThumper's Avatar
24c
NJThumper is offline
Old 06-26-2008 | 05:41 PM
Natural juice works fine for me, at least for the first half hour or so. Then, spit.
baddogz28 is offline
Rob
I thought the 101 green was for like needle bearings on the inside for Assembly?? Also its thin
Clay Washington's Avatar
The definition of hot sex...
Reaching for the KY jelly and getting the BenGay instead!
Clay Washington is offline
