225 promax with no power
well after 2 hrs of my motor running good it now has no power.won't rev over 2000 rpm under load,sometimes it surges up a few hundred rpm but has no power.changed spark plugs,ignition wires,all fuel filters with no change.anyone have any idea's
i did have a alarm go off for a few seconds but that was way before the motor lost power.i blamed that on a loose connection.the alarm never came back and when it went off all gauges were normal.what can set the alarm off don?
Oil Bottle Level switch, TPS, Water Pressure, Temp...... Just to name a few.
If the alarm went off that usually means that the engine should be put on a computer to read the codes. This is really the only way to know what happened.
