Trim Tab crapped out - need help >
Old 07-07-2008 | 11:04 AM
Default Trim Tab crapped out - need help
This weekend one of my tabs (K-Planes) decided it only likes going down. I can here the relay clicking but no motor running. I'm about 90% sure it's the relay. If only I had a nice little wiring schematic (hint, hint)
Hot Stepper is offline
Old 07-07-2008 | 12:07 PM
Revelocity's Avatar
I would think that the wiring would be virtually the same as a trim pump. I would bet you could temporarily swap out your trim pump relay to check your k-plane operation.
Revelocity is offline
Old 07-07-2008 | 12:33 PM
Velocity Vector's Avatar
Crazy Energy
I had the same experience and it was the solenoid, bout 18 bucks.
Velocity Vector is offline
Old 07-07-2008 | 03:31 PM
It's most likely the solenoid Part# 89-96158T. The Red wire off of the pump is power, the green wire is for tabs down & the Blue wire is for tabs up, so it would be the solenoid with the Blue wire.
Arch260 is offline
Old 07-07-2008 | 04:34 PM
Check the grounds, my Formula had the same problem all it was was a crappy groung on the case not letting the full 12 volts and amps to the motor.
Andy is offline
Old 07-08-2008 | 09:23 AM
Wally's Avatar
Were doomed!
you can also get the relays from Napa
theres two different ones...one fits the older versions so bring one of your old ones along or take a pic of it and compare
Napa Part#'s 18-5815 and 18-5817
If memory serves me right it should be the 5817 number....the other may be for the starter solenoid on the back of the engine...
-Wally
Wally is offline
26sonic
04-30-2008 03:08 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
Python82
03-14-2006 06:08 PM
Monty
6
05-16-2005 01:24 PM
MnFastBoat
05-04-2005 08:34 AM
