Go Back  Offshoreonly.com > Owners Forum > Awesome
cant get on plane >
cant get on plane
cant get on plane
Old 07-07-2008 | 10:33 PM
Default cant get on plane
wtf, i bought a 260 fx and for some reason it cant break the prop loose! newer motor, new ignition, fuel pump, 25 p trophy prop. anyone with suggestions?
jaytate is offline
Old 07-10-2008 | 10:25 AM
fantastixvoyage's Avatar
Hey jay - its neil was with Dan the day you had it out.
Anyways, check the basics first - fuel, timing, etc. That motor should be making more than enough to break that prop loose. Also, check for bad gas. Revs fine in neutral but really struggled to make power underload. overcarbed maybe?
fantastixvoyage is offline
Old 07-10-2008 | 08:10 PM
I have a 26 awesome it now runs 115mph 968hp. When i first got it 8years ago i put a 520hp motor in it and it had a hard time comming on plane. the motor had no low end torque the prop will not blow out comming on plane it`s the way it is with a full tunnel cat (no center pod) single engine. Your motor is weak.
26awesome is offline
Old 09-13-2008 | 11:15 AM
Default Have you figured out the problem with your 26 ft yet?
We have a 26 ft for sale and have gone through it, it runs great.
allenbruce is offline
eeasy
5
07-29-2008 10:02 AM
Craney
4
09-11-2005 10:24 PM
Shah Mat
06-21-2005 08:49 PM
mtgbiker
2
04-21-2005 02:54 PM
blue64drop
6
11-11-2002 11:46 AM
