How Fast 1994 Sonic 42 Triple Hp500? >
Old 07-09-2008 | 06:23 PM
jeff32's Avatar
Default How Fast 1994 Sonic 42 Triple Hp500?
i JUST CAME BACK TO SEE ONE. WHAT PROP ARE SUPPOSED TO BE ON THOSE?
THEY ARE 1.5 RATIO BRAVO, BUT HAD 22 4 BLADE MACK PROP??????
I THOUGHT IT WOULD SPIN HIGHER PITCH THAN THAT... BUT IF THAT IS THE RIGHT PROP SET UP, THAT WOULD REACH WHAT... 70-75?
jeff32 is offline
Old 07-09-2008 | 08:52 PM
Jassman's Avatar
Jassman is offline
Old 07-09-2008 | 09:10 PM
kr1276's Avatar
Not a chance with 1.5's and 22 pitch! More like in the high
60'smaybe 70 with that set up. Should be able to run 25-26's which would get you in the mid-high 70's on 4 blades.
kr1276 is offline
Old 07-09-2008 | 11:14 PM
sunchaser796's Avatar
45 SONIC triple 575 sci 86 tops running Bravo Drives turing 4 blasdes. Have to check the props and sea whats on there. Anything faster than that is on a trailer going downhill with a tail wind. No Ransom, triple 900 Teague motors running #6 drysump drives 104 tops .
sunchaser796 is offline
Old 07-10-2008 | 05:38 AM
Jassman's Avatar
he said trips..not twins.. A 42 with twin 500's does 69-71...I had one.
Jassman is offline
Old 07-10-2008 | 08:55 AM
PatriYacht's Avatar
Must be a mistake somewhere. A 42 with 2 502 MPI 415 hp will turn 22 pitch 4 blades and go 60 mph +. With 3 500's it should go 78-80.
PatriYacht is offline
Old 07-10-2008 | 09:00 AM
45sonic's Avatar
OK OK. 42 Sonic with 500's 24p or 26p running right at 70.
45 Sonic with triple 575's running I believe 32p runs right around 90.
386 With twin 900's #6 drives not sure of prop ran 106 all day.
My 45 triple 500EFI's turning 26p runs right about 80
Madcow on here has a triple 42 not sure of what power or props.
Or for more reading:
http://www.offshoreonly.com/forums/s...t=sonic+speeds
45sonic is offline
Old 07-10-2008 | 10:31 PM
Checked the pitch on two of the Sonics at the shop today. Triple 575sci are running 28" pitch. The 42 SS Boarder Line running triple 650 Inovations I believe is running Hydro-motive 4 blades 31" pitch. Note sure of the speeds but should be in the low 80's. She is listed in the boats ads for sale. http://www.offshoreonlyclassifieds.c...o23275-en.html
jeff32
Sonic
7
07-28-2008 06:08 PM
jeff32
Sonic
3
07-01-2008 08:32 PM
jeff32
06-16-2008 10:06 PM
gofast000
Sonic
34
11-25-2006 07:01 PM
Cattitude
1
08-01-2004 09:51 PM
