$ 3500 to play with, lets make the boat faster >
Old 07-10-2008 | 08:53 PM
Default $ 3500 to play with, lets make the boat faster
just like it says have some money to spend on the 2001 454 non mag with bravo 1, 1.50, and 23pitch mirage everything BONE stock with 200hrs on motor. need more top end. what should i start with? headers, roller rockers,? give sum suggestions please!
01hammer is offline
Old 07-10-2008 | 08:58 PM
ROB FREEMAN's Avatar
pull that motor sell it , take he two combined cash and buy a 540 never look back !!
ROB FREEMAN is offline
Old 07-10-2008 | 10:44 PM
Thats works do it !!!
formula 382 sr-1 is offline
Old 07-11-2008 | 08:13 AM
Give me $2000 for my new lightning headers and spend the rest on gas!
kennyo is offline
Old 07-11-2008 | 08:21 AM
jryan26's Avatar
Give me 2000 for a procharger and offer Kenny 1500 for his headers!
jryan26 is offline
Old 07-11-2008 | 11:29 AM
Wobble's Avatar
SORE MEMBER
talk to these people http://www.raylarengine.com/kits.html
seem to have plenty of satisfied customers here.
Wobble is offline
Old 07-11-2008 | 12:04 PM
ENFORCER24's Avatar
my first question would be , are you doing the work yourself , or does 3500 have to cover a mechanic and parts ?
if soo , 3500 bucks will basicly get you a pro-charger and install , a very notable increase in performance , but it will cut the life of the engine in half if your non mag engine is the cast internals
if your have the ability to do the work , 3500 will cover set of used rect port heads , intake , carb , and camshaft ,496 exhaust and needed gaskets to assemble , keep in mind that again if you have cast internals in your engine your gonna wanna use a cam profile that keeps max rpm below 5k
just my .02 , so far basicaly the same things are working great in my engine
ENFORCER24 is offline
Old 07-11-2008 | 02:24 PM
Hydrocruiser's Avatar
Arrow
It's a half spent 2 bolt main engine.
I agree selling it may bring in enough along with the $3500 to get something new with more power and reliability.
Rebuilding is not a bad idea....if you can find a builder who is reasonable priced and will bore it out ..new cam..headers maniflow...etc.
Bolting thigns on an engine with 200 hrs will result in problems..
Hydrocruiser is offline
Old 07-11-2008 | 05:48 PM
lucky strike's Avatar
Put a straight edge on the back 15 feet of the bottom &
make sure it's perfectly straight to the transom.( no hook )
Wet sand & buff the bottom of your tabs & drives.
Start there for some cheap speed !
lucky strike is offline
Old 07-12-2008 | 12:16 AM
KAAMA's Avatar
There are some exceptions to the rule, but either way you slice it, you will need a better breathing exhaust system. Adding go fast upgraded induction parts like cams, intakes, ported heads, etc, are not going to make your boat go faster if you do not get rid of the exhaust efficiently such as an aftermarket (better breathing) exhaust system. So, you might as well get that expense out of the way and spend the money for it now because without it you're only going to be frustrated if/when you begin to buy/add upgraded go fast parts.
The exception to the rule is if you add a supercharger/blower you can side step the use of an aftermarket exhaust and still retain the stock exhaust system---but depending on the cam being used you need to be careful of water reversion with some systems/set-ups, but blowers still run much better with a good exhaust system---most engines do.
If it was my money I would buy a better breathing aftermarket exhaust system FIRST---but that's just me. Whatever you do I hope it goes well for you---have fun.
KAAMA is offline
