34 cat engine forward mounting questions >
Old 07-11-2008 | 09:05 AM
fastlane40's Avatar
Default 34 cat engine forward mounting questions
I'm trying to figure out how i can mount the motors forward.What is used to couple the motor to the drive?Do you do away with the coupler?Rear engine mounts?Can you buy the required parts?Help please..
fastlane40 is offline
Old 07-11-2008 | 09:09 AM
fastlane40's Avatar
Here's a pic of the boat i'm rigging.
Attached Thumbnails 34 cat engine forward mounting questions-img_20080708_9258_4.jpg
Old 07-11-2008 | 09:21 AM
P Offshore's Avatar
If it is an I/O application.....
Mercury sells all the parts, mounts, etc... Driveshaft may have to be custom built depending on the length.
P Offshore is offline
Old 07-11-2008 | 09:23 AM
Registered User
Is that an outboard boat? If so, you'll probably have to redo the stringer system in the rear to accommodate a mounting system. The drives you use will dictate how the rear mount is configured. If what I'm seeing is a molded-in well for the outboatds, that's probably going to have to be removed. If you mount the motors too far forward, it's going to shift the center of gravity drastically and make the boat lethally dangerous at speed.
Chris Sunkin is offline
Old 07-11-2008 | 10:15 AM
fastlane40's Avatar
It was an outboard boat.Will be cutting away the well and installing all the necessary glass needed.I am unsure as too mount the motors at the rear or move them forward.I will be using XR drives.How do you couple to the motor?
Old 07-11-2008 | 10:51 AM
Registered User
The Bravo doesn't use a transmission. There is a coupler that bolts to the engine flywheel and a bellhousing that bolts to the rear flange on the engine. On the back of this bellhousing is the rear mount- it engages the inner transom assembly of the drive. The front mount would be any standard offshore-style mount that would bolt to the pads on the sides of the block.
I would speak to the boat's manufacturer or maybe track down one that's rigged with I/O's and check it out.
Who built the boat? Looks like an Apache.
Old 07-11-2008 | 11:14 AM
Just Curious... What make of boat is that? What size?
Don
Maritime_Eng is offline
Old 07-11-2008 | 04:34 PM
fastlane40's Avatar
Guys thanks for the input.I have done/rigged/fitted heaps of Bravo style motors/drives with the rear mount sitting on the inner transom plate.I just need to know how to couple them when i forward mount the motors.The splined shaft of the drive normally fits in to the coupler.But what do you do if the space between the 2 is say 30"?The boat is what we call over here a Victory cat.It's a 34 and i'm planning 2 x 632's to start with before switching too a set of 525's and running in our Supercat class.I currently run my Eliminator 27 in Production Unlimited.If your interested in our offshore racing check out www.aopc.com.au . This boat is fully rigged for clamp on's,actually 2 x 300's and it ran a few races in our Supercat Outboard class.
Old 07-11-2008 | 04:42 PM
fastlane40's Avatar
Couple more.Let me know what the hull reminds you of.
Attached Thumbnails 34 cat engine forward mounting questions-_rap0012_0398.jpg   34 cat engine forward mounting questions-_rap0009_0395.jpg   34 cat engine forward mounting questions-_rap0006_0381.jpg
Old 07-11-2008 | 06:45 PM
P Offshore's Avatar
As I stated earlier Mercury has everything....
The rear motor mount will fit between the block and flywheel
Mercury makes a kit for a bravo driveline setup I bought them for a 36 Spectre I had built.
Do you have access to Mercury parts?
