tiller arm question >
tiller arm question
tiller arm question
Old 07-14-2008 | 12:59 AM
rslick's Avatar
Default tiller arm question
I am in the process of installing a new larger oil cooler. It is going behind the engine. It fits well but the tiller arm comes in contact with it. I would like to cut it off for clearance. I have full hydraulic steering so the tiller arm is not being used. Any thoughts on if this is a bad idea?
rslick is offline
Old 07-14-2008 | 03:23 AM
hillbilly24's Avatar
As long as you have full hydraulic steering it will not matter at all. You can't remove it though because it mounts on the swivel pin for the gimbal ring and the nut would not tighten without it. You could make a spacer to replace it but you are best off just cutting off what you need to for clearance. Make sure it is clear throughout it's range of motion too.
hillbilly24 is offline
Old 07-14-2008 | 12:46 PM
Mr Gadgets's Avatar
Charter Member #601
Like hillbilly said.. you can cut it off without a problem.
Mr Gadgets is offline
kennyo
0
06-02-2004 04:47 PM
patrick22309
5
04-30-2003 12:35 PM
blue thunder
26
11-25-2002 06:02 PM
patrick22309
11
11-19-2002 08:03 PM
