low water pickup question
Old 07-14-2008 | 10:19 AM
Default low water pickup question
okay this is the first outdrive of mine that has a low water pickup, and unfortunantly i brought the boat into shallow water by the beach and sucked sand, ruining my water pump.... other boats i have owned have the
intakes on the sides of the drives... they are obviously better for shallow water boating, is there a general preference here as to which is better,
pros and cons on the low water pickup?
should i replace the lower
or just install sea strainers,
avoiding slightly shallow water is not really an option in my area
i just have to use more care when going to these places
any thought or suggestions would be appreciated
lennyk is offline
Old 07-14-2008 | 10:32 AM
Wobble's Avatar
SORE MEMBER
sea strainers are always a very good idea, I have had all three types of pickups and can say that the nose cone type are problematic if you have to deal with a muddy bottom, the dual pickup or older style side only will be more reliable.
Wobble is offline
Old 07-14-2008 | 10:35 AM
Registered User
You need a good, tall strainer that works on swirling action if you're around alot of sand. Regardless of what pickup you use. The low water pickups are a must for drives with high X dimensions and drives that get trimmed up. Those side pickups can't take water in if they're not under water.
Chris Sunkin is offline
Old 07-15-2008 | 06:41 PM
Don't Trim Up Leave Paralel With Bottom Of Lake.if You Trim Up It Sticks The Pickup In The Bottom
schnydo is offline
Old 07-15-2008 | 07:19 PM
Mine was a low water pick up only,spoke with a Merc rep at a show and he told me I could drill the sides and make it a dual water pick up,
he told me to only drill 4 holes per side,never had a problem since
boatnt is offline
GregP
4
06-13-2007 03:50 PM
SSComp
1
12-25-2005 10:40 AM
kilroy
07-21-2004 08:34 AM
kilroy
2
07-19-2004 02:00 PM
BadDog
14
05-19-2003 04:18 PM
