Cruisair 12-volt Air Conditioning Unit >
Old 07-16-2008 | 01:10 PM
Clay Washington's Avatar
Default Cruisair 12-volt Air Conditioning Unit
Does anyone know anything about these units. I would think that 3500BTU would be plenty for the cabin of my Bullet.
http://www.cruisair.com/self.html
http://www.cruisair.com/sheets/L-2425D.pdf
Clay Washington is offline
Old 07-16-2008 | 01:23 PM
The Cruisair unit is a 115-volt 3500btu unit that comes with an inverter.
Or, would I be better off with a true 12-volt system like the DB Breeze unit?
Old 07-16-2008 | 01:24 PM
tblrklakemo's Avatar
SeaRay Sundancer
also check http://www.cruisencomfortusa.com/mescompressor.html
They had a small write up in the latest powerboat mag. You will probably need a extra battery or two just to run these.
tblrklakemo is offline
Old 07-16-2008 | 01:53 PM
Yes, I plan to add two more batteries in my Bullet to run the A/C unit.
However, would I be better off getting a true 12-volt system, or buying a 115 system and an inverter. I know the inverter would add to my costs, but I would be able to also use the 115-volt outlets that currently only work when I am connected to Shore Power.
Old 07-16-2008 | 02:24 PM
I doubt if a 3500 btu unit will keep your cabin cool in the Texas sun. You would probably need about a 7000 btu unit.
Griff is offline
Old 07-16-2008 | 02:25 PM
SeaRay Sundancer
hmmmm.....dont know. Somebody smarter than I will hopefully chime in. I would like a full 12 volt system with its own batteries and a charger that i could plug in when back on my lift. I guess something w/o an inverter would be best so you have less complication. But if you want to use your outlets than you kinda need the inverter.
Old 07-16-2008 | 02:28 PM
HiPerf2000's Avatar
you're better off installing a regular unit and running a portable 4 stroke generator. my honda 2000 plugs into my shorepower with an adapter, and will run my a/c, fridge, and battery charger for 7+ hours on 1 gallon of gas.
HiPerf2000 is offline
Old 07-16-2008 | 02:54 PM
SeaRay Sundancer
non-diesel generators make me a little nervous around gas fumes in an engine compartment.....I think thats why most will install a diesel gen in a gas boat.
How much your honda weigh?
Old 07-16-2008 | 06:17 PM
I can get a 9000btu unit for $1075 HERE, I believe that 9000 btu's for my cabin is overkill.
Old 07-16-2008 | 06:18 PM
Yes, that is a option for over-nighting, but not a very workable solution for daytime rafting up in the cove.
