Why not fiberglass?
a solid fiberglass transom is gonna weigh about a thousand pounds or more
there are some composite methods such as Coosa (
. . . yes . . . i said it) but i dont care for it in the high stress offshore environment.
08 OPA High Points Champion
Registered User
Two simple reasons...
1. "If it ain't broke, don't fix it".
and
2. Cost.
Plywood just works. It has good weight-to-strength ratio and failures are pretty much non-existant. Composites are more rot resistant but on a well-built and properly-maintained boat, wooden-cored transoms don't rot anyway. Composites aren't totally waterproof either- ask anyone with a big cruiser that didn't keep up with gelcoat blisters- the repairs can be very expensive.
A transom could be made out of a composite material-combinations of plys, cores and honeycombs. But why? The failure rates are next to zero. For equivalent performance the weight savings would probably be single digits and the cost addition would be in the thousands.
and
2. Cost.
