SBC oil flow confusion >
Old 07-17-2008 | 07:22 AM
Default SBC oil flow confusion
I finally rigged my remote oil system on one of my new engines and seem to have oil flowing in 2 different directions at the same time. I used a block adapter and filter mount from Hamburger's Perfomance, neither of which sport any sort of bypass. Both pieces have clearly marked "IN" and "OUT" ports. To my knowledge small Chevy blocks do not have any type of internal bypass.
First pic shows the whole setup.
Seccond pic shows oil flowing out of the proper "OUT" port on the block.
Third pic shows oil flowing out the hose end that connects to the "IN" port on the block and completes the loop. At the same time a small amount of oil is also flowing out of the "IN" port on the block, its not bleed off becase it starts and stops with the drill. I'm no expert buy why would it be flowing in 2 different directions?
Attached Thumbnails SBC oil flow confusion-007.jpg   SBC oil flow confusion-oil-001.jpg   SBC oil flow confusion-oil-002.jpg
THRILLSEEKER is offline
Old 07-17-2008 | 11:29 AM
Wobble's Avatar
SORE MEMBER
I have never tried that, but I don't see how there could be a problem. I'm assuming that you are able to generate good oil pressure with the drill?
Wobble is offline
Old 07-17-2008 | 11:35 AM
Im gonna try again tonight and hold my thumb over the "IN" port to see if it builds any pressure.
RonS
9
10-02-2008 09:11 AM
duunoit
18
05-19-2007 09:14 PM
boatman747
6
10-18-2005 09:11 PM
502procharger
3
07-12-2004 01:51 PM
HighPriority
4
05-24-2004 08:56 AM
