Myco Trailer Break Problems
Old 07-17-2008 | 07:04 PM
Default Myco Trailer Break Problems
I Have A Myco Trailer It's A 12000# ,the Disc Breaks Keep Locking Up If I Stop Thay Will Not Release Like Thay Should. If I Drive It Like That For 15 Miles Smoke Is Comming Off Them.it Has Kodiac 250 Calipers Any Idea?
dennis r is offline
Old 07-17-2008 | 07:38 PM
INDY27's Avatar
The problem is either the acuator not releasing when you take off or the pistons in the calipers sticking....easy fix either way. Check the actuator first.
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 07-17-2008 | 09:14 PM
Registered User
A 12K trailer really should have electric over hydraulic. it's much smoother, more linear braking and WAY safer. If you lose truck brakes, the trailer can still stop you. If you're having actuator trouble, this is the perfect time to switch.
Chris Sunkin is offline
Old 07-18-2008 | 12:22 AM
handreasen's Avatar
had same problem here, rebuilt 250's,that was not the problem, had an old Ausco e/h actuator, replaced with a new system. all better now.
handreasen is offline
Old 07-18-2008 | 10:10 AM
lucky strike's Avatar
Had the same problem.....Greased the actuator, no problem for a while.
Then on the way home from Key West some studs broke off a wheel & when we stopped for lunch I noticed the wheel was gone. I tried to tighten the others & snapped two studs off.
I think from when the brakes locked up before it heated up the studs & took the temper out of them...Replaced all studs.
lucky strike is offline
Old 07-18-2008 | 12:05 PM
Schweeng's Avatar
My buddy just had similar problems on this '05 Myco....Actuator was bad....Myco paid for the Actuator to be replaced. Trailer guy out her on the west coast says the actuator that Myco is using is not the best out there....
Schweeng is offline
Old 07-18-2008 | 03:50 PM
Jassman's Avatar
is this actuator the same thing when you hit the brakes you dont get a smooth linear braking but more of a jerking motion when trying to stop..or is what I have something different. Thanks Jeff
Jassman is offline
jmackin
9
06-14-2008 02:38 PM
lonestar382
16
10-19-2005 06:23 AM
Downtown42
05-15-2005 08:09 AM
Downtown42
Fountain
23
05-11-2005 11:13 AM
Steel Outlawed
Baja
2
03-18-2003 04:26 PM
