Watch Out Hauling Boat Trailers Through Pa >
Old 07-23-2008 | 12:05 PM
fabin61's Avatar
Default Watch Out Hauling Boat Trailers Through Pa
Anybody hauling through PA, be aware that if you don't have brakes on all wheels on all axles, you will get pinched with a $100 fine! However, if your not hauling your boat constantly it's not really worth getting it fixed to avoid the fine as my uncle is doing a ton of work on boat trailers and to get brakes put on is running about $700-900.
$900 vs $100. It's your call!
fabin61 is offline
Old 07-23-2008 | 12:45 PM
Scott B's Avatar
Most states have adopted the anything over 3000 lbs must have working brakes on all axles.. DOT can pul you and red flag you, meaning you have to have it transported to a repair shop and brought to standard before traveling on...
Scott B is offline
Old 07-23-2008 | 01:44 PM
Never Enuff
Why do some trailer manufactures continue to put brakes on only two axles of a triple axle trailer if the standard is brakes on all axles. Is this standard something that is more recent than 06 or does it apply to only some states?
Jay
never enuff is offline
Old 07-23-2008 | 02:06 PM
Wobble's Avatar
SORE MEMBER
Is this a new law?
not listed here http://www.roadkingtrailers.com/brakelaws.htm
found this though http://www.pacode.com/secure/data/06.../s175.123.html
Wobble is offline
Old 07-23-2008 | 07:47 PM
rchevelle71's Avatar
I was told it is the law, precisely why my new triler has brakes on both.
rchevelle71 is offline
Old 07-23-2008 | 10:28 PM
If you also notice, maximum trailer length in NC is 35' or 10,000 GVWR. Anything beyond that requires a different class driver's license. It is the shortest/lightest of all 50 states. Can't legally pull most triple axle boat trailers in NC with a std driver's license. I believe it requires a certain class of Commercial driver's license. Always made me nervous when I lived in NC.
bob_t is offline
Old 07-24-2008 | 03:22 PM
All of this should be federally regulated so that all states are the same. Towing state to state with different regs is a real pain!
Screamin' Seamen' is offline
Fenderjack
03-10-2008 08:21 PM
fountain 47 sc
12
08-20-2007 07:11 PM
bgchuby01
12-30-2005 03:28 PM
littledcsrodshop
07-30-2005 07:18 AM
bgchuby
04-30-2002 05:58 PM
