Smart Craft help
Old 07-23-2008 | 04:21 PM
Default Smart Craft help
Ya know the best part about boats… there’s always something to do and you’re never bored. I’m in the Bahamas and the local Merc dealer only handles outboards, so I’m turning to the OSO board for advice.
I ordered two Smartcraft SC1000 System Monitors and wouldn’t you know it, the installation is not going “smooth”. Just found out that one engine needs to be programmed to be the "none starboard" engine. Does anyone know if the same tool used on Verados could be used to program my 377 Merc 08’ engines?? If so, is it straight forward… because the outboard dealers not to accommodating, and I would basically need to know what to do.
Second question…
It looks like the System Monitors show the outdrive trim level using something built into the drive( I think I’ve seen it on the side). If so , is there any reason not to take off the mechanical indicators and cables? Taking those cables out would free up some room in the rigging tube so it would be easier to get the Smart Craft cables to the helm.
Austin is offline
Old 07-23-2008 | 04:43 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You are correct about programming the engines. They both come from the factory thinking they are SB engines. I do not know the tool needed to do so, but I would imagine it is a laptop with the Mercury Software. I don't know if the Rinda tool can make this adjustment. You will need a Mercury Mechanic to confirm what needs to be done.
As for the mechanical indicators; leave them installed if at all possible. They will be more reliable and perhaps more accurate than the electronic ones that come with the drives.
Sydwayz is offline
Old 07-23-2008 | 04:48 PM
Thanks sywayz. Any Merc mechanics out there???
Austin is offline
Raypanic
4
12-16-2013 10:43 PM
SCARAB98
3
08-06-2008 07:07 PM
bskater18
02-02-2008 06:22 PM
Nauti Kitty
06-02-2002 11:40 PM
