Old Merc. 350 mag heating up.
350 Chevy block. Lower unit is off, impeller like new. What would cause motor to run hot? didn't overheat,, just running hot so I quit using it.
Thermostat? Any good and easy way to check water flow?
BTW it's running hot on higher RPM's
Thx
p
Thx
p
Bad risers will do that.. Also, just because the impeller looks good doesn't mean the rest of the pump is. Check the base and upper housing carefully. Next step is to check the entire water system. Backflush everything, see if pieces of old impeller or whatever are stuck in it. Last, pull risers, inspect for blockage..
Check the hose that comes off the transom plate inside of the transom.I know it is hard to get at and inspect but I had one that was restricting flow at higher RPMs.
Paradox where in Florida do you live?
I was thinking the same thing. There have been a number of guys that have had the hose kink/ collapse due to age.
BTW, if you back flust it and it flows well it could still be bad and collapse under suction.
Darrell.
Registered User
You say the pump "looks good" so I assume your getting water out the exhaust so the raw water pump is flowing. Overheating at higher rpms could mean a few things.
1. Passages blocked by pieces of impeller or chunks of rust.
2. Bad Thermostat
3. Disintegrated or disconnected impeller in the recirculation pump.
Also get a cheap mechanical temp guage and screw it in place of the electrical one. Just a thought... IS your temp guage working right?
2. Bad Thermostat
THanks 29.. My mistake.. I should have said the "impeller lokos good" not just the "pump"
Impeller is removed and changed. THe old impeller did not had any peaces missing and was still fexible, not dry.
Will check thermostat and all the water ways. guage is good.
Possible circulating pump on the block.
More research is due.
Thx
Thx
Time for lunch with the Avanti.
