Which trailer hubs to go with?
Old 07-29-2008 | 10:42 AM
Default Which trailer hubs to go with?
I'm shopping for galvanized hubs for 3500lb axles. The spindles are Posi-lube? with the center grease zerk. I've seen Tie Down/Long Run complete hub kits that have a grease zerk behind the flange for about $75. I've also seen some hub kits on Ebay for ~$35. The Loadmaster Trailer Parts (Florida) catalog lists bare hubs for about $20.
How many different hub makers can there be? Besides the grease zerk, and making sure the bearing sizes are correct, what other differences should I be looking out for?
handfulz28 is offline
Old 07-29-2008 | 10:58 AM
Registered User
A hub is a hub, as long as the flange is square and the bearing bore is cut right.
I would definitely recommend these-
http://www.airtighthubs.com/products-sport-5200.php
Chris Sunkin is offline
MDSmitty
45
09-15-2008 04:30 AM
tomcei
Prop Talk
3
09-28-2007 09:24 PM
jmherbert
1
05-16-2007 12:04 AM
jmackin
Prop Talk
2
04-24-2006 11:38 AM
JnT
7
07-20-2003 01:34 PM
