32p verses 28p >
32p verses 28p
32p verses 28p
Old 07-30-2008 | 01:21 PM
Angry 32p verses 28p
I have a 35-0 fountain ex with 496 ho the boat came stock with 32p wide open I am only seeing 68-69 if I change to 28 p will that give me more speed?I don't hear a lot on 32's from the factory.
sonic28 is offline
Old 07-30-2008 | 01:52 PM
What are your WOT rpms? You will raise your RPMS 200 to 300 rpms dropping to a 30p.
Also, if you lab your 32's, you could gain 200 to 300 rpms, while still turning a larger wheel,,,, better performance!
Carder
Carder is offline
Old 07-30-2008 | 02:14 PM
thank you Carder I am running 4900-5000 rpm wot
sonic28 is offline
Old 07-30-2008 | 03:36 PM
32" props running 68-69 @ at 4900-5000rpms?????
What gear ratio drives???? Even with 1.65's the prop slip is way high.
Griff is offline
Old 07-30-2008 | 03:56 PM
Default 28s vs32s
Food for thought what about 5 blades for alittle more transom lift ?
tony manzella is offline
Old 07-30-2008 | 05:57 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Slip is bad. Need to determine why first.
5 blade props can be the ticket on hulls like yours. The 4 blade props should be better than they are though.
[email protected]
bbladesprops is offline
Old 07-31-2008 | 10:28 AM
Red face
please explain prop slipage why would this happen everything is stock.I still question the 32p verses 28p
sonic28 is offline
Old 07-31-2008 | 12:58 PM
You're already spinning the 32" props at the right rpm. 28's would theoretically spin about 800rpms faster. Your engines would be hitting the rev limiter at 5100rpms.
read this about prop slip
http://www.go-fast.com/prop_slip.htm
Griff is offline
Old 07-31-2008 | 03:42 PM
thank you Griff
sonic28 is offline
Boomer35
Prop Talk
0
10-28-2008 08:00 PM
CMG
9
06-07-2007 10:53 PM
REDDEATH
Saber
26
10-23-2006 05:35 PM
thunderdan
55
06-08-2006 10:49 AM
tssteph
Prop Talk
5
08-04-2005 04:07 PM
